- Jan 26, 2017
Thank you so much Uwe.Very clean and accurate work - your pplanking will look very good![]()
My deepest respect for your fantastic work.... incredible and from scratch...respect respectHull planking continues. Since each plank is prepared separately and glued into place with PVA, the progress is a little slow.
View attachment 401502View attachment 401503View attachment 401504View attachment 401505View attachment 401506View attachment 401507View attachment 401508View attachment 401509View attachment 401510
Marc, thank you for stopping by. You're doing a great job with Old Ironside, too. I'm following.My deepest respect for your fantastic work.... incredible and from scratch...respect respect
Marc
Thank you Tony. It's actually not easy at all. As you know, hull planking is the most difficult and time consuming part of a building. Each plank is individually measured, cut, tapered, heated and bent, then glued into place and allowed to dry. But in the end, doing a good job makes one happy.Hi
Your planking is great it's funny how it always looks easier and better when someone else is doing it.
Tony
I order a little thicker and wider planks than what I need and I cut them to size with my table saw to ensure standardization.Yes, indeed.... Are you buying the planks or are you making each plank yourself?
Marc
Are you building USS Constitution too? If so, do you have build log on SOS?Great work on planking the hull. I know it is a tedious job as I am also at that stage. I do have the advantage of an almost solid hull making it easier to get the planks tight fited.
Thank you. I will be watching your build.I am not building the Constitution, but "De 7 Provinciën"
I do have a buildlog on SoS, but not of direct interest for specific details on the Constitution.
DE 7 PROVINCIËN (1665) 1:50
I have chosen for building this ship as my father left me the book "De 7 Provinciën" by G.C. Dik. A book that comes with a set of plans (1:77). Years later I decided to actually build this model. I wanted the model to be a bit larger than it would be on a scale of 1:77, envisioning a completed...shipsofscale.com
Thank you and you are welcome.She is coming along very nicely. Thank you for sharing your build with this forum.
Thank you so much Uwe.Very good work on the planking -![]()
