The photo is not working - maybe you edit your post or attach it once more - Many Thanks in advancePractice planking. View attachment 127898
This what I have found. I am thinking that I will remove the gun ports again. Install the first two planks and then re-install the gun ports, creating new slots as appropriate to get the gun ports flush to the planking as shown in the drawings.John
You need to check the heights of the gunport positions against the main drawing.On every Mamoli build I have seen,the positions of the slots in the bulkheads have been all over the place.Most builders have had to make adjustments to get the correct line to the ports.
Kind Regards
Nigel
Thanks will do. It is frustrating. I want to get to the rigging, but getting past the low quality of this kit is getting to me. I'm 76 so I need to get it going.I'm following your build. Also just starting a Mamoli. Mine is the Victory. Seem to be finding some of the same problems as you. Even though this is my 8th build, it still gets extremely frustrating. Especially for what they charge for these kits. I find that you need to double, triple, and quadruple check EVERYTHING.!!!!
I'm going to try the Alert kit next. ( the one they've been discussing here on SOS). Then a scratch built..
Once again, for the quality and what they charge for these kits is ridiculous. I surely can't screw it up any more than they do.
Keep at it man.... it's always worth it in the end when you complete something that's neat and unique and can sit back and beam with pride.
I have measured from the keel on the drawing to the top of the first plank. According to the drawing the gun port should be snug against the plank. As you see there is enough space to put another plank or a plank and half. I am stumped. I can make it snug by moving the gun ports an average of 1/4 inch up. Should I ?
By the measurement from the keel it is 11mm, exactly where the slots are. The first plank is where the drawing shows it to be. If I leave everything as shown instead of the first plank being flush with the gun ports I will have to add another plank or a plank and a half to be flush. How will that affect the overall planking.Hi John,
I should not do that, this as your lower deck gunport would then be at the height of tghe upper deck.
Maybe it is better to measure from the upper deck and take this as a reference.
Maybe there is also a false keel to be installed influencing your current measurement.
