....are we having fun yet?.....
11 cm not mmBy the measurement from the keel it is 11mm, exactly where the slots are. The first plank is where the drawing shows it to be. If I leave everything as shown instead of the first plank being flush with the gun ports I will have to add another plank or a plank and a half to be flush. How will that affect the overall planking.
Thank you.I had the same problem when I built the Santa Ana. The plans were wrong. When the gun carriages were built they didn't fit. I realize you are dealing with false guns, but the same principle. I actually had to measure each gunport from the deck and cut the holes from there. Remember, you also need to keep in mind rubbing strakes and gunwales will be added later. All these things need to flow together. Maybe average the distance and line them all up.
I'm not sure? The frames meet the reference line. The gun ports are driving me crazy. If I remove them a third time I am going to damage the frames. I still think I should install the first two planks and installing the gun ports.Hallo,
just by looking at your photo I have the feeling, that the bulkhead marked with the red arrow is sitting too high, therefore also the gunport location looks wrong.
Please check it - now is the best time to correct if necessary
View attachment 129849![]()
I am really getting frustrated with this model. I'll work it out some how.I'm not sure? The frames meet the reference line. The gun ports are driving me crazy. If I remove them a third time I am going to damage the frames. I still think I should install the first two planks and installing the gun ports.
Also, one part of the drawing shows the first plank up against the false deck, but another part of the same plank going under the false deck.
Since this my first wooden ship should I remove the gun ports again and then install the first plank?
View attachment 130002View attachment 130003
The frame you marked is number 12. I can not see that it is too high, but my vision is bad. It is same height as the frame 14.Hallo,
This is my first wooden ship build. I guess do over think each step. I feel the instructions and drawings should be accurate, but as you and other have said you can't take the instructions and drawings as 100 % correct. Since I am new, I tend to place too much emphasis on each step.Hi John
I think you are placing too much emphasis on where the kit "sketches" show where the planks fall and overthinking things.This does not matter in the slightest to the finished model.
Your deck in the latest pictures has a smooth flowing sheer.I do not think the bulkhead is too high,I think the shape is wrong and will need scrap timber gluing to it's edge before fairing otherwise you will have a dip on the underside of the hull.
I have Mamoli's Royal Louis drawings and so far as accuracy is concerned regarding bulkheads,they are complete garbage.The drawings aren't even symmetrical so it is no surprise that have seen issues with many Mamoli builds on the net.What you are supplied with parts wise is something approximating what you should get.
You need to focus on achieving gunport placement to the main drawing,forget the existing port slots as a lot of these will be out and as you mention,the castings are not a consistent size.Also forget any sketches that show where planks are supposed to fall in relation to the stern galleries.I do not think even Mamoli drew these as gospel.
The simple way to look at it and the way I would do it,is you need one full planking below the port casting and one above.This distance between is the height of the casting.This should follow a natural arc that is parallel to the outer edge of your deck.Set these planks first,then slot in and glue the castings.Adjust any oversize castings with a file if they are too high to fit between.
Kind Regards
Nigel
