Marvelous Heinrich. I'm so glad you came back to the Batavia/Haarlem! I share your interest in these Dutch-built ships and am learning a lot for my own build. Thanks for leading the way!
Happy new year to you and Anna
She's always in my mind@shota70 Hello my dear friend. Thank you for your very kind words - they are much appreciated. I miss you continuing your build on the Friesland. I know that Hannah is occupying all your time, but don't forget the Friesland!![]()
That is good to hear my friend. I am glad that you have not forgotten about her!She's always in my mind![]()
Now that would be an absolutely wonderful gathering - can you imagine how much of an exchange of ideas will take place? And what an opportunity to show politicians all over the world what is really important in life!I am waiting and praying for the day when the corona plague will pass, and thet we will return to a normal life and we will finally be able to meet at a shipbuilding conference. It would be nicer, to meet all of you , my dear friends
Pffff! Now you can hit an iceberg with your ship - and the iceberg will sink!
A lot of work - but it turned out quite well! (Except for the walnut keel part).
In the planking proces two options are possible in this stage:
1: Bend en mount the planking in a way it is a little bit too long so it goes a few mm over the false keel. Then - when your new keel part has arrived, use this as a template to draw the outlines (width) of the walnut keel onto the planks and cut away the ends of the planks so the keel fits exactly in between it.
2: or sand the planks nice flush in the rounding of the hull and cut out the thickness of the planks out of the new-to-arrive keel part so it fits over it.
And Ab Hoving is right when he says that balsa is no wood. In fact it is wood, but it is no real construction wood. It does not really add strenght or whatsoever to the hull. It merely gives you a good indication of how your planking should go and how the lines of the bow part go.
The bow of Dutch 17th century ships was quitte blunt (I don't know if this is the correct word for it), but I mean that the bow is very round shaped and therefore rather difficult to form. Once you have experienced the bending and gluing of the first planks you will appreciate the extra wood in front.
Hans
