Willem Barentsz by Kolderstok AD 1596
Sorry to hear about your redo Jan, but remember this, You can only stop the redoactions when you are happy with the result.
She now looks great. and that is what counts
The model shipyard work area needed to be modified. The hunching over, the back stress and constant ache of Sciatica was getting old. I think I found a good alternative.
The work surface is 24 X 40 inches. The table can be raised and lowered by the push of a button. The assembly was straight forward and took about an hour.
The new shipyard dry dock.
( No the puppy didn’t come with it)
Very nice and clean working dry dock, I wish my was like that.
@Heinrich
Sitting in our Sun Room with my morning coffee, looking at last night snowfall, I’m reading, re-reading your WB posts. Piece #11 bothers me. Did you add that piece and “fair” that section of the hull before you added the rear keel piece or was the keel piece added and then the “fairing“ done.
Last nights snow fall
Nice winter scene to wake up to.
Here in Miami I have to set my thermostat to 70 just to sleep comfortable because of the heat.
Jan, a little more info on your adjustable work table. How sturdy is it. I don’t want to sit on it just don’t like lateral movement when sanding and such.
I think you are right about being happy with ones results. Compared to the Port side the Starboard side had taken on a life of its own. So... a Re-Do was required.
Hi Ron, the table is pretty rugged and heavy. I can't move it by myself. The legs are quite heavy and the top is almost 3/4 inch thick which adds to the weight,
This is the highest position that I use. I can stand and work on the WB and be comfortable vs sitting and bending over the work.
The lowest position, I've used this one to work on the Sternwheeler while working on the upper decks.
I was great to be able to adjust my work height especially when I was rigging my Alert.
I've not fastened any thing to the table top to do any "rigorous" sanding, but I'm fairly certain the table would be stable. Just my opinion!!
Hi, thank you for stopping by. Welcome the log, glad to have another kibitzer on board.
I like the seasons up here in the North country. Yup we have cold, snow, hot, rain, mud, black flies, etc. But I learned that the old salts here were right about Maine weather. "It ain't all that bad if them tourists keep coming back"ROTFROTF
The SB side planking.
I decided to finish the planking above the Wales (I keep breaking off the tops of the bulkheads). My theory is - since the tops of bulkheads 1 - 6 will be removed later in the build and I had come to hate that tiny snapping sound when I broke one it was the least of the two evils, (ie. planking up or planking down).
Tomorrow todays work will be sanded and filled prior to placing the cap rail.
The planking process continues. I'm making very slow progress.
Adding the plank above the SB garboard plank and closing in on the Cheshire cat's grin.
It's all about time. Dry fit the plank, soak the plank, use the K iron to form the bow bend, pin in place and wait for the plank to dry out and then fit and diddle with it until satisfied and finally glue it in place. Then repeat the process for the net plank. (@Henrich, much easier with Walnut than with Oak, eh?)
You are almost there now, Jan. The walnut is much more pliable than the oak.
@Heinrich, I think I have a question on the placement of the cap rail and the extra wale. But first I want try to get the hull closed in today and do some initial sanding.
No problem my friend. Shoot when you are ready.
Good morning Jan. The “slow progress “ is paying dividends. Looking awesome. Following Heinrich’s log it is clear this little Dutch ship requires patience and a one plank at a time approach. You are owning this. Cheers Grant
