Wright Brothers "Flyer" 1903
Hey Daniel
I just discovered your blog!
Great piece of craftsmanship that you show
I can imagine that you wanted to do something different for a few ships
Regards
Henk
Hello Henk, I'm so glad you found my build. Welcome aboard. This project is a nice change of pace but still has sewing and line rigging involved which fortunately I have experience in.
Good Friday evening everyone. I have assembled the rudder for this Flyer which was just more stick work and fabric wrapping. Only the exterior gets the covering.
Here is the build process. The upper and lower exterior strut supports the ferrule's that the rudder hinges off of.
No more sewing, halleluiah!!
Here is the plan I was working off.
Till next time have a great weekend.
Completing the rudder assembly parts with the struts that attach it to the wing frame. Then placing the wire x-bracing which was very straight forward after viewing the actual plane's rudder bracing. Take a look.
What the real plane's rudder bracing looks like.
Next I built out the elevator frame and added its wings to it. This was very awkward to do, I needed extra hands but only had patients and 1-2-3 blocks to help.
I did add a pinned hinge at each cross point which really helped.
I'm getting close to having to do away with the multi jig, just trying to get all I can done ahead of this step.
Thanks for looking in.
View attachment 479368View attachment 479369View attachment 479370
View attachment 479373View attachment 479374View attachment 479375View attachment 479376View attachment 479377
Still going strong with the build, Daniel. You can see the ‘lightweightness’ of the build.
Were the microscopic eye-bolts pre-fabricated, or did you make those yourself?
Hello Namabiiru, the eyebolts are actually the head of Dry-Docks 0.60mm brass nails. I cut the nails in half; hand drill a shallow hole through the cloth into the wood to place the nail into.
