YES RICH I ALSO USED THIS IT IS THE FIRST PAGE OF THE FRAME DRAWINGS MADE 2 COPIES. GOD BLESS STAY SAFE YOU AND YOURS DON
Now, with your lead I found it. Previously went straight to the frame(s) drawing page in my haste. Now I can add your annotations. Thanks. Rich (I apologize for my sidetrack deviation of your time.)@PT-2 Hi rich. It is the very first page in the frame instruction manual - it is actually separate from the rest of the frame-drawings.
Hi Heinrich,@Pathfinder65 Hi Jan. Great to hear from you. Yes, the log serves a dual purpose - on the one hand it is a build log, on the other, it is an instruction manual for our aspirant builders.I use two wooden cheese/bread boards and have also modified the Leudo's building jig to serve as a surface. The cheese/bread boards are too wide - hence I can only clamp the centre section and one side at a time. With the Leudo's jig, I can clamp both sides and the centre section all at once. There are going to be some frames that are too big (wide) for my specially modified Leudo jig though!
Hello Jan, I like to use a piece of glass with the edges sanded down to avoid cuts, most glue will not stick to glass.Hi Heinrich,
Excellent, my curiosity was peaked because of the need to have a good flat surface while working with frames.
Jan
That is the same as the bulkhead "frames" in MS2130 where we are instructed and shown to cut/file away the after/rear face creating a more narrow station at the deck level. The inward face of these are also shaped to parallel the outer curve of the side. The remaining thicker bulkhead portion which crosses the schooner becomes the deck beam. The YQ frames eliminate this removal process.So the frames are double thick on bottom, but single thickness at top of frames?
Just trying to understand without kit or instructions in front of me.
Keep up the great instructional build for all of us bound to follow behind you when we get our kit out for work.
Heinrich,Hello Gentlemen
I have to start by saying that it is wonderful to see how the kits are arriving and how the build logs are being started. I don't have too much report from my side as I have been making frames - and the process is exactly the same as I have described in my previous post. However, I have finished 10 x frames and have test-fitted them out of curiosity!Please note that I have just removed the char prior to assembly. After assembly, absolutely nothing has been done to the frames - no sanding/polishing or finishing of any kind.
There is still a v-e-r-y long way to go until there is light at the end of that tunnel!
If we use PLENTY of imagination, we can already see a hull shape developing.
So in the coming week the goal remains churning out more frames - and like Don said - at the end of each week, we hope to have filled that jig some more!
Thank you all for following and for supporting Bluenose! Stay safe out there, look after yourselves and enjoy your building!
The keel is exposed as you have shaded it along with the stem post for the rudder. The bow stem should eventually begin to be tapered from a square edge to one less wide as it progresses form the point of departure from the straight keel bottom to the upward curve and then at the very end under the boom again be wider for a gammoning metal connection. You can see some of this in the old photos of Bluenose and supplemented by me MS2130 vetted kit. .. . I cannot say what YQ instructs as I have not begun my build, just watched. Rich (PT-2)Heinrich,
Just a question about the parts 20 and 21.
On your the picture I made them grey:
Are this cover planks for the keel or are they intended to strengthen the keel. To give it its strength by the 3 layers with overlapping seams and give it body?
Because, when the port side is planked, these parts are still in sight.
In fig.20 I made them also grey.
In a other way: is the wood of the keel covered with (protection) planks?
Perhaps @PT-2 Rich ore somebody else can say something about this question?
