"Houston, we have a problem!"
I measured the left and right side of each and every frame and.... drum roll, I have different lengths for almost every single frame.
Here is the visual presentation with the length of my H.M.S. Victory.
Here is a table with frames and lengths in millimeters between them.
| Frame | Left Side (Top), mm | Right Side (Bottom), mm |
| Between 3 and 4 | 27,5 | 26,5 |
| 4 and 5 | 30,2 | 32 |
| 5 and 7 | 66 | 67,25 |
| 7 and 8 | 69,2 | 68 |
| 8 and 9 | 65,5 | 64,8 |
| 9 and 10 | 72,5 | 74 |
| 10 and 11 | 68,2 | 66 |
| 11 and 13 | 66 | 68 |
| 13 and 14 | 30 | 30,3 |
| 14 and 15 | 22 | 21,25 |
| 15 and 16 | 37 | 36,5 |
I did measure right before the gun sides and the top like below on the picture. Except between frames 15 and 16, where I checked the very top length.
From your experience, will this difference affect the build a lot, or it is a matter to do more sanding before gluing plunking strips?
Up until now, I was under the impression that my model's sides are perfectly 90 degrees deadly right (except the first 3 frames as I wasn't sure at all). But now, when I used my new ruler, it seems like I might be in trouble.
Looking for an advice.
