I thought you didn't know when, so I just simply remind you!!! LOLThank you Jim. But my birthday was last week.
Happy Birthday Mike!!!
     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
what oil finish do you use on this build?Thanks Jim, that is an oil finish that I use.
Mike as silly question on ship design, why let water in just to have to pump out again?Hi Jim,
Thanks, the notches let water run back to the well house to be pumped overboard.
Mike
Otherwise too boring to be sailor LolMike as silly question on ship design, why let water in just to have to pump out again?
Boats leaked! The well, where the pumps are located, is the lowest point on the ship. The idea was to get the water to the well so it could be pumped out. The frames could prevent water from flowing, trapping it between adjacent frames and leading to rot. The notches allow free passage of water despite the frames.Otherwise too boring to be sailor Lol
Hi Kurt,Mike as silly question on ship design, why let water in just to have to pump out again?
Those notches are called limber gates.Indeed, nice to see progress and start of the frames assembled on the kell. I have a question: The middle notch is where the frame goes to the keel. What are other two notches both sides (indicated with red arrows)?
Thank you Ray, what is the purpose of limber gates?Those notches are called limber gates.
