- Jun 12, 2020
Many Thanks for starting this log - I am very happy, that I was able to convince you - GreatI shall start a thread of my construction after Uwek made a convincing argument for me to post my adventure.
This is were I am up to with my build.
I will continue.....View attachment 165210
did you get any intructions or plans that are in english, my kit just arrived to day..I shall start a thread of my construction after Uwek made a convincing argument for me to post my adventure.
I use the “google translate” app on the iPad.did you get any intructions or plans that are in english, my kit just arrived to day..
These elements are looking very good - well done - very accurate workDeck 3 cabins in process and the bread oven.View attachment 165465View attachment 165466
That was the error - I used the 2mm thick strips for the pump hold walls and did not have more for these sides. I used 1mm thick strips, hence space for only one layer of doors. As far as the beams - the whole assembly, beams and cabins, slides in.These elements are looking very good - well done - very accurate work
I guess the sliding doors are movable, due to the fact, that you installed on both sides the frames.... but you installed only the door, so you will show them open I guess....
Be aware about the fitting of the beams for the next deck into the notches of the interieur walls and the framing - it was a little bit tricky in my section model
