- Aug 21, 2020
I just got my Scale Decks too. I have used Gorilla glue on my Constitution Scale Decks, with excellent results.Have you started fitting your Titanic decks yet? I know it's the Connie, but in the Connie album I managed to load in here, you can see the Scale Decks that were lain down with the Gorilla Wood Glue. That stuff works!I have received my decking from ScaleDecks. I sealed them with Testor Dullcote on both sides. I hope that eliminates the expansion while gluing as described in the instructions for the deck material. Scale Decks recommends Gorilla wood glue but I have seen people recommending Gorilla Acrylic Hobby glue also. I am wondering what the pros and cons are.
brass or nickel
I primed and painted while still on the sprues. I didn't use to prime anything, now I try to always use primer. It's supposed to make the paint adhere better. It does seem that my finishes are more durable and scratch resistant. I will touch up any brass that shows after removing from sprues with a paint brush.wow! I just ordered the pe from Tom's. Do you prime the pe? If so, while it is still on the sprues?
Micro sol and micro set might help.Looks great. I didn't put the stripe on mine as I couldn't figure out how to mask over the raised rivets. Now I wish I had tried harder. Yes, the decal stripe looks like nothing but a bunch of aggravation! I used Gators Grip glue and a lot of clamps for the decks. So far they have stayed put.
Yes that was my first model in many decades so there was a bunch of stuff I didn't know. I didn't even put any decals on it. I discovered the Micro Sol/Set and haven't had any issues with decals on the last two ships I have built. Still learning lol!Micro sol and micro set might help.
Priming is important. I never bothered with priming before doing the Constitution, but began with that. I am priming everything on the Titanic. What do you think of using blackening agents on the brass pe?I primed and painted while still on the sprues. I didn't use to prime anything, now I try to always use primer. It's supposed to make the paint adhere better. It does seem that my finishes are more durable and scratch resistant. I will touch up any brass that shows after removing from sprues with a paint brush.
blackening agents
