the magic of photography!Your windows look good.
That's what I like about this hobby - there is usually no limit to "do overs"! The exception would be the Scale Deck - "do over" there = $85. The most important skills/qualities seem to be patience and perseveranceYour ship is doing well. I had to repaint the hull, the water line was too low.
thanks. I haven't put any of the decks on yet so I can't say anything about the fit. My next project is the steam wenches. still deciding how much I want to do to them. At a minimum I will replace those ball thingy's with the concave pulleys.That's a great job and the Scale Deck looks terrific. I set my Dremel workstation up for the same reason, pin drills are hard to control! Did you get your decks to fit properly? They don't seem to line up out of the box.
I am just at the point where I am ready to install the main deck (kit parts D1/2) I am curious what issue(s) you ran into. There are 2 ledges along the inside of the hull - I'm not sure why the lower one is there (other than to add confusion). The ledge in the hull for the fore section of D1 appears to be too low to be useful.That's a great job and the Scale Deck looks terrific. I set my Dremel workstation up for the same reason, pin drills are hard to control! Did you get your decks to fit properly? They don't seem to line up out of the box.
I hope that helps. Getting the main deck on was like releasing a log jam. I'm making good progress nowI bought some strip styrene to glue onto the hull, to see if that will make it fit better.
