heheh the admiral would send me to the dog house
Luczorama is proud to launch a 4-week scavenger hunt giveaway packed with creativity, laughs, and nautical nonsense. Explore historic ships, solve easy clues, and have some fun with fellow builders. Complete weekly missions to earn raffle entries — the more you join in, the better your chance to win a Fram model ship by OcCre! **VIEW RULES HERE** |
Thanks, Daniel. I'll check those out. I appreciate the tip!For the small Vasa decorations you can buy something like these brushes with archival ink:
Get also a set of Markers with Archival ink. They came in a sort of point sizes. Some very small !!
Paint all the small details with them, let the archival ink dry very well and cover with clear Poly (the one of your preference)
Go to your local craft store. Buy 1 marker and a Brush pen (like the Amazon example) and try them on a piece is photetched brass or whatever you want to use to test them.
You will see how precise you will be under the magnifier.
Cheers
Daniel
Thanks, Donnie. I appreciate the encouragement. I'm in over my head but hopefully more experienced builders (like yourself) will rally around my build. I certainly need the help!This is going to be really good to follow !!
WOW! The lions are spectacular. You may try bring out the detail with a light wash of diluted brown paint for to enhance the shadows. Do a test piece first and see if you like the effect. You want it to be subtle. I noticed that modelers often add washes to add darkness to areas to simulate the effect of ambient occlusion and depth. For some reason, the way light plays on a model is different somehow. If you spend as much time on the rest of the ship as you have with the lions, you'll have a real work of art when it's finished. The trick is not running out of patience.Having spent nearly 8 hours yesterday laying hull planks (the product of which was only 6 lines of planking on each side of the ship) I decided to do some painting today. I had a free afternoon so I chose the lion's heads that festoon the gun port covers. Here is what I ended up with:
I'm considering whether I need to add some shading to the recessed areas of the mane. I added some very subtle highlights but feel like the whole thing comes across as a bit monochromatic. Since I'm not an experienced miniatures painter I'm struggling with technique. And after painting 57 (!!!) of these bad boys I needed to take a break before I ruined anything...
Thanks for checking out my build log and feel encouraged to share your suggestions for improving my work!
I used very thin 7mm push pins with a pin pushing tool and left the pins in the model, since if you push hard enough the heads bury themselves in the plank and don't protrude.Well, it was back to placing hull planks today. I am getting better at shaping the strakes but there is still some flaw in my approach that leads to small to midsized gaps between wood strips - especially in areas of convex curves. Wood putty will be my friend...
Things I have learned:
What else should I have learned?
- Embrace the process - progress is slow and perfection is a vapor that cannot be captured.
- Back-bevel the lath strips (thanks, Kurt) so they fit more snuggly along their length.
- When adjusting planks adjust only one side (I'm using the top side since I am presently working from top down). Doing this preserves a virgin edge for the next plank to align to. I figured this out a little too late...
- Don't only glue the plank to the frames - also glue it to the adjacent plank.
- Get better clamps - or use pins/nails the next time...
- A long soak in water helps - but lath strips break anyways.
- The strip that breaks is always the one you have invested the most time in. Always.
- It is not your spouse's fault when the strip breaks - don't take it out on her/him when she/he asks how things are going.
- There is something oddly satisfying about seeing the hull take shape under your own hands.
Hi Uwe, thanks for checking in. I have no idea why I marked the frames on the outside of the first planking!Very good work and also the a very good learning curvewe should never stop to learn and often it is trial and error
So we should also accept sometimes the "Error" - we should not make the same errors twice.....
BTW: What is the reason, that you marked the location of bulkheads on the outside of the first planking?
I have not much time today, to clarify this more in detail - but you are right, that the instruction is wrong - usually every line of planks have to end in the keel.Hi Uwe, thanks for checking in. I have no idea why I marked the frames on the outside of the first planking!
I guess I assumed I would need that information later but since you're asking I guess the answer is that I won't. See - I really am new at this!
For the record, I don't like the way I have been told in the instructions to plank the hull. They very explicitly say: follow our pattern because you'll need these specific plank locations for measuring something later (I assume for gun ports?). The problem with the layout they suggest is that it includes planks that end at a spear point in the middle of the curve forming the bow of the ship. No drop planks. But in 1628 the Dutch contractors hired to build the ship would have used drop planks, right? I have looked ahead and see the instructions call for repeating this planking pattern in the second layer. See the following image from the instructions:
That's incorrect isn't it? I'm a long way from doing the second planking but I sure could use some advice here! I've looked at pictures of the original vessel at the museum and it's hard to see the planking pattern on that part of the ship.
FANTASTIC UWE! I knew enough German to get myself registered. These images are amazing - far better than anything I have seen on the internet. They will be immeasurably valuable. I am in your debt and thanks to your friend for posting these.I have not much time today, to clarify this more in detail - but you are right, that the instruction is wrong - usually every line of planks have to end in the keel.
The Vasa was somehow very very special, because they often did not follow normal regulations, f.e they shaped tapered the ending of a plank sharp and did not use stealers or butt joints in the planking
I do not know, if you can see the photos in this german forum (without beeing a member), but a very good friend of mine visited two years ago Stockholm and made a lot of detailed photos of the Vasa
Forum für historischen Schiffsmodellbau und Geschichte
Projektorientierte Quellensammlung und Datenbank für historischen Schiffsmodellbau und Geschichtewww.segelschiffsmodellbau.com
also these photos will help
Pretty much sums up the Hobby!!Very good work and also the a very good learning curvewe should never stop to learn and often it is trial and error
