Hi Eric, your frames will be okay, if you start your project with a build board and or a jig it is easier to keep track of your progress. When the jig is complete build the keel and place it in the jig. You will now be able to fit each frame to the keel and make any required adjustments to the frames or the notches in the jig to make sure the frames are in alignment and perpendicular to the keel. It usually works out better to make the notch in the frame match the keel notch. The frames are fine but will require a little extra work.Thanks, guys. Cant seem to manage more than one frame a day, but it does move forward. Last frame should be done tomorrow, and then ill need to get the framing jig together. How concerned should I be that these aren't aligning perfectly without the jig?View attachment 176539View attachment 176540
you can define every piece of timber like a Whiskey timber..... your work is looking very goodLast frame complete. Is there such a thing as a whiskey timber?
I'm off to Home Depot for jig supplies.View attachment 176643View attachment 176644
Quality might suffer a bit, but hey!you can define every piece of timber like a Whiskey timber.....
Will do.Yes, the brass should be blackened to simulate iron bolts.
@DocBlake , when I install the keelson, should i use nails to clinch all the way through to the rising wood, or just glue this and mimic more bolts?Looks great! Good progress!
