Hi Uwe, does this “turning the right futtocks 180 degrees “ start from a certain frame nr ?Now I have one tip for the Le Coureur newbies which will start the build and the works with the frames.
Each normal frame is build with the use of five elements / parts. Take a close look at the description of the manual
Part "c" are the floor timber - every frame has one
Parts "a" are the top timbers - every frame has two, which have the same form, but different mirrored laser lines (for fairing)
Parts "b" are the futtocks - every frame has two, which have the same form, but different mirrored laser lines (for fairing)
Here you can see construction of frame 32, which is showing the fairing lines very good and it easy to see by the fairing line to find out, which one has to be installed on the left and which one on the right side of the frame. With the red arrow is shown that this futtock has to be put on top
The other futtock (marked with green arrows) has to be turned around by 180 degrees, so that the areas marked in red have to touch each other
Remark: This is valid for the bigger number of frames, but.....
Unfortunately this rule is not followed on all frames - some are different
-> so you have take a good care and take two times a look of the shown fairing lines
f.e. take a look at the first frames I made:
So please be patient and never switch of the brain - latest when you start to fair you will realize a mistake
No - I was also thinking first about the midship frame towards fore and aft..... but NoHi Uwe, does this “turning the right futtocks 180 degrees “ start from a certain frame nr ?
I found that using the jig to fit the frame also helps in checking the fairing, particularly how the top of the frames fit into the slots which indicate the exact angle.At the end - it is important and the aim, that the frames are looking like this
When all frames of the Le Coureur are prepared and installed on the keel, I will compare the reality with this CAF - drawing - Let us see the result in some time
- I already wanted to write an e-mail to CAF asking for spare frames to make everything new....
Does something like this (see below) is also happening to you sometimes?
Yesterday evening I was working / fairing some frames - and during this I was thinking about the postings here (post #42ff) in our forum.
With this in mind I wanted to store the already prepared frames in two frame-"towers" with one from midship fore and one midship aft, in order also to see the "nice fairing" for the clinker planking.
And I got a shock![]()
- it seemed that in direction aft the frames were all prepared wrong.
With these drawings (excerpts in the following) in mind, showing, that all floor timbers are into direction aft!
sideview and topview
View attachment 183933 View attachment 183934
and I got a 15 minutes "panic-attack"- I already wanted to write an e-mail to CAF asking for spare frames to make everything new....
How can this happen?
Why to me? Especially because at the same day I wrote such post like #42 !?!?
and I remembered also the last post by @Chello talking about the jig (#47) ..... best to check the frames inside the jig - a last prove before I write to Tom from CAF
So fast I removed the parts of the jig and stick some of the main parts dry together - putting the keel inside (it fitted well btw) and put all made frames on top of the keel inside the jig
AND:
Everything fine
all frames are in the correct direction (floor timbers in direction aft) and all frames faired until now also correct - PUH
I do not know, why I was thinking somehow completely in the wrong direction - black out
So here some photos of yesterday late evening (for info: jig only partly dry installed and no accurate arrangement of the frames - pure check situation)
Very good and I am very happy to hear this!Hallo Uwe,
it looks so great. Besides I experience such shock situations more often. But when you're fully occupied with your work and you take it very seriously,it's probably normal.
Besides, you motivate me so much that I started with the keel yesterday.![]()
That’s great news!! I strongly advice to start a log and I can tell you from experience how it is helping me. It’s not about show boating skills but all about sharing and learning together. Give it a go!Hallo Uwe,
Hello Chello,That’s great news!! I strongly advice to start a log and I can tell you from experience how it is helping me. It’s not about show boating skills but all about sharing and learning together. Give it a go!
Possible definitely! I was asking myself also the same thing and decided to make the beveling after the parts of one frame are fixed togetherCongrats on your first milestone Uwe! So...just to sum up for other builders... You have to bevel each 'notch' on the frame. Can you bevel\shape before assembling the frame parts together, or it is not practical\possible?
BTW: all together you have to sand and fair more than 1.500 steps![]()
