LE COUREUR - french Lugger 1776 - POF kit from CAF in 1:48 by Uwe
One very good news - I just received the missing parts E1 and E2 of the cradle jig (only some days transport - very good after sale service by CAF)
So now no more excuses........ ;)
Now I have one tip for the Le Coureur newbies which will start the build and the works with the frames.
Each normal frame is build with the use of five elements / parts. Take a close look at the description of the manual
Part "c" are the floor timber - every frame has one
Parts "a" are the top timbers - every frame has two, which have the same form, but different mirrored laser lines (for fairing)
Parts "b" are the futtocks - every frame has two, which have the same form, but different mirrored laser lines (for fairing)
Here you can see construction of frame 32, which is showing the fairing lines very good and it easy to see by the fairing line to find out, which one has to be installed on the left and which one on the right side of the frame. With the red arrow is shown that this futtock has to be put on top
The other futtock (marked with green arrows) has to be turned around by 180 degrees, so that the areas marked in red have to touch each other
Remark: This is valid for the bigger number of frames, but.....
Unfortunately this rule is not followed on all frames - some are different
-> so you have take a good care and take two times a look of the shown fairing lines
f.e. take a look at the first frames I made:
So please be patient and never switch of the brain - latest when you start to fair you will realize a mistake
and another small but very helpful hint.
When I prepare the single parts for a frame, before gluing them together, I am sanding shortly also the two surfaces of the parts (in order to remove some char dust and to smoothen the surface.
Before you put the five parts together and you arrange them at the correct place, take a stiff brush and remove the sanding dust away from the fairing lines.
Simple working step, but you will recognize the lines much much better than without brushing.
Here you can see the differences:
When you see the lines better you can adjust the location much easier and the result is much more accurate....
Hi Uwe, does this “turning the right futtocks 180 degrees “ start from a certain frame nr ?
No - I was also thinking first about the midship frame towards fore and aft..... but No
I marked the frames with red color - so it is 8, 9, 10, 16, 17, 21 and 22 which are different (Remark: I did not make frames 1 to 7 until now)
I guess it happened with arranging the parts on the wooden billets - every billet is lasered from both sides
BTW: I had one rule in production: the lasered frame number on the floor timber was every time visible when I glued the frame-parts together, and the lasered frame number is every time only on one side of the timber
At the end - it is important and the aim, that the frames are looking like this
When all frames of the Le Coureur are prepared and installed on the keel, I will compare the reality with this CAF - drawing - Let us see the result in some time
I found that using the jig to fit the frame also helps in checking the fairing, particularly how the top of the frames fit into the slots which indicate the exact angle.
Does something like this (see below) is also happening to you sometimes?
Yesterday evening I was working / fairing some frames - and during this I was thinking about the postings here (post #42ff) in our forum.
With this in mind I wanted to store the already prepared frames in two frame-"towers" with one from midship fore and one midship aft, in order also to see the "nice fairing" for the clinker planking.
And I got a shock :eek: Speechless :mad: - it seemed that in direction aft the frames were all prepared wrong.
With these drawings (excerpts in the following) in mind, showing, that all floor timbers are into direction aft!
sideview and topview
and I got a 15 minutes "panic-attack" Sick - I already wanted to write an e-mail to CAF asking for spare frames to make everything new....
How can this happen?
Why to me? Especially because at the same day I wrote such post like #42 !?!? :mad:
and I remembered also the last post by @Chello talking about the jig (#47) ..... best to check the frames inside the jig - a last prove before I write to Tom from CAF
So fast I removed the parts of the jig and stick some of the main parts dry together - putting the keel inside (it fitted well btw) and put all made frames on top of the keel inside the jig
AND:
Everything fine Exclamation-Mark
all frames are in the correct direction (floor timbers in direction aft) and all frames faired until now also correct - PUH
I do not know, why I was thinking somehow completely in the wrong direction - black out
So here some photos of yesterday late evening (for info: jig only partly dry installed and no accurate arrangement of the frames - pure check situation)
View attachment 183933 View attachment 183934
AND:
I certainly recognise that state of panic, I have it regularly! :-) looking mighty impressive Uwe and I can’t wait to pick up the work again this weekend. I have requested the admiral to grant me attic leave
Hallo Uwe,
it looks so great. Besides I experience such shock situations more often. But when you're fully occupied with your work and you take it very seriously,it's probably normal.
Besides, you motivate me so much that I started with the keel yesterday.:)
Very good and I am very happy to hear this!
So I hope we can expect in short time the start of your building log, or ??? Please
Hallo Uwe,
That’s great news!! I strongly advice to start a log and I can tell you from experience how it is helping me. It’s not about show boating skills but all about sharing and learning together. Give it a go!
Panic attacks are normal and I had my share, believe me. It is often that you wish you could back-up a step and
correct a wrong, make something a little more perfect, or re-adjust a shoddy glue job. We all strive for perfection
that is almost impossible to obtain.
I look forward to presenting my Courier log soon.
jb
Yesterday I was able to make and to fair some more frames.
And I was finally able (this time without panic ;) ) to make the two "frame-towers" - really nice to see the future form of the hull growing - step by step I am coming to the end, which is planned for coming weekend
BTW: all together you have to sand and fair more than 1.500 steps Exclamation-Mark
Congrats on your first milestone Uwe! So...just to sum up for other builders... You have to bevel each 'notch' on the frame. Can you bevel\shape before assembling the frame parts together, or it is not practical\possible?
Possible definitely! I was asking myself also the same thing and decided to make the beveling after the parts of one frame are fixed together
After I made some experience with the frames I think it will be better to make it really afterwards.
1) With this you can achieve a more accurate edge on the teeth where the frames are "double"-sided, means at the connections between futtock and floor timber or futtock and top timber - see here the green lines
2) also on some frames the last step is not a complete one, so it would be more problematic to bevel these areas in the correct angle - see here the red arrows
