Maybe double sided tape between timber and paper could also be used? (I'm thinking, easy to remove)
Yes easy to remove, but not easy to fix on the paper correctly - there is no possibility to adjust the location of the part on the paper, and here you see 1/10 of a mmMaybe double sided tape between timber and paper could also be used? (I'm thinking, easy to remove)
Hallo @ChelloI like the idea of lightly glueing the frame timbers to the drawing. I have completed the keel and will next prepare and assemble the frames. As Uwe and others have already mentioned, this appears to be a very time consuming and accurate part of the build where mistakes are not easily rectified. As there is a lot of very time consuming filing and removing of char and laser lines involved it seems a good idea to invest in some quality files. As it also involves a lot of fairing I was wondering if we had some feedback from @CAFmodel /Tom or other opinions as what would be the best time to bevel / fair the frames as Uwe mentioned before,
1) To fair before gluing the parts of one frame together - than maybe only some smaller corrections afterwards
or
2) Glue the parts together and fair them afterwards - like I did in the first frame
or
3) Only light fairing on the area where the frame is connected with the temporary jig and fair the frames just before the planking
I know exactly what do you mean, Poul, and understand your fillingsI must admit though that I struggle more and more as time goes by to keep my hands away from the boxes with Le Coureur
Poul, you probably heard: Resistance is futile!I must admit though that I struggle more and more as time goes by to keep my hands away from the boxes with Le Coureur
Don't fight it, it only gets worse if you don't dig in and do something!When I have not started a build log yet it is because it will probably take a long time before I start the build. I have no experience at all with this hobby and for now I don't want to start building 2 models simultaniously. I had planned /hoped to build the Alert (or at least the main part of it) before starting on Le Coureur. I must admit though that I struggle more and more as time goes by to keep my hands away from the boxes with Le Coureur
Hi Uwe, are these files the ones you used on the frames ( Corradi-Nadelraspel-Set 220 140 H2 )?after one day the new needle-file sets arrived already
Purchased shortly ago / sthg new in your workshop -> present it here
Ewe, they were a special order for me. I was most impressed with the quality of these cast brass anchors, as they are far superior to anything else available.shipsofscale.com
so I have no argument any more......
Hallo,Hi Uwe, are these files the ones you used on the frames ( Corradi-Nadelraspel-Set 220 140 H2 )?
I definitely need to invest in a set of good files considering all the filing that needs doing on the clinker steps on all the frames
