Hope @Maarten don't mind to answer. It is Cherry, for the most part. And you are correct, it is of really good quality.Lumber in the kit looks great. What is it? Thanks.
Well, I've never seen such a good quality cherry, very different from what I got in La Belle kit. Thanks.Hope @Maarten don't mind to answer. It is Cherry, for the most part. And you are correct, it is of really good quality.
It is certainly not bad. Not so delicate and compact as pear but with fine sanding and scraping it gives an excellent smooth surface finish.Well, I've never seen such a good quality cherry, very different from what I got in La Belle kit. Thanks.
I am not an expert on Cherry wood, but this one is of excellent quality and very consistent in color and grains.Well, I've never seen such a good quality cherry, very different from what I got in La Belle kit. Thanks.
These bolts are clenched and also visible on the outside.Bolts are not visible from outside of the frame?
The smallest I could get is 0,8 mm. Sure will test and documentI love the way you layout the cant frames! This template technology is very effective, and you executed very-well: clean and accurate (no gaps)!!! Applaud!
You will love the burr technology. Try using the smallest for the wire 0,4mm and cut wire flash before 'burring' Make sure to show the results.![]()
