Started the first layer of hull planking...I’m not concerning myself too much about it laying down perfect because I have to cover it with a second layer.
Thanks, I actually rushed it since it is just the first layer. But I can't get careless or it will create more work! I figured the taper to the bow and kept full width at the stern to keep from having to use stealers, but now I think need to start tapering at the stern too. I need to slow down and measure before I start again!That planking looks very nice !!!.
Daniel
Yes, when I planked the Norske Love, the stern was a nightmare due to hard bends going up at an angle, yet the bow was easy.Nice real nice the stern look to be more easy to do compare to the Corel one![]()
I think I messed up by not setting that bend with the hair dryer before doing the bend from the top view.
I actually looked online for a plank bender and they were sold out everywhere? I will look again tomorrow for the brand you mentioned.Once again, I can strongly recommend the Kolderstok plank bender. Any other device just does not work as effectively.
Just a word of caution before you will order. The Hans bender tool is 220v of current. Unless you have 220 volts outlets, you would need to get a 'step up' transformer (expensive). If possible, to get just an attachment (the bending head), then you can mount it to a soldering iron with 110 volts (USA). Obviously, you will need to get the size of the bending head insert.Dean just send Hans (@Kolderstok ) a PM. He is a member on SOS. He will set you right in no time!
All correct what Jimsky says here. The Kolderstok plank bender is a very helpfull device - but originally designed for the European market and every other country which uses 230 Volts. But as Heinrich said: I can sell the two heads of this plank bender separately, and you have to buy a 30 Watt, 110 Volts soldering iron locally with a 4-6 mm shaft.Just a word of caution before you will order. The Hans bender tool is 220v of current. Unless you have 220 volts outlets, you would need to get a 'step up' transformer (expensive). If possible, to get just an attachment (the bending head), then you can mount it to a soldering iron with 110 volts (USA). Obviously, you will need to get the size of the bending head insert.
