I finished sanding and prepping the first layer of planking on the hull.
Now I am adding the boards to the transom prior to starting the second layer of the hull. I have to trim the boards and sand flush once I get all of them on. Then it’s on to the hull, which will be as tedious as the deck.
Also, note the areas that have a yellowish tint from wood glue. Being the first layer of planking, I just put wood glue on with a brush in any areas that the boards were not glued to each other well, which you will know because there will be movement. If a board can move up and down, due to not being glued to the adjacent boards well enough, it will never level! That is because when you sand it and put pressure on the board, it will push the board down level with the adjacent boards and when you stop sanding it will move back up, and still remain higher. If you chase this without gluing it, you will become frustrated quickly and will end up sanding too much off the adjacent boards. So if you have a board that moves, glue it and then sand. Also this will help fill in between boards.
