Great thinking from Trident Model...luckily there are 6 pieces in the kit and only need 4.
Thx Uwe.My friend -> Beautiful work
PS: I like the bold-heads also very much - I will try this also
One question about this to @Maarten and @Jimsky :Thx Uwe.
The tip from @Jimsky works great.
Answering on my behalf. You are correct, if you make the wire a.c.a. bolt flush with the frame - you cannot make the head with the bur. So... you will make those bolts already rounded (both ends), and then just push them thru the hole after the final sanding (inside-outside). However, if you drill hole 0.38 ~0.39mm drill bitt, the wire should go tight into the wood and shouldn't twist while 'rounded' the head.One question about this to @Maarten and @Jimsky :
When you have the wire sanded flash with the timber - How you can keep the burr really on top of the wire / nail?
I have the fear, that if you start the drill and the burr starts to turn, the burr will walk over the timber surface and will not stay exactly over the bolt?
It is possible to do it, I did it with these test pieces. Just press the burr on the of the wire. My bur is 0,8 mm with sharp edges. My wire is 0,4 mm so the burr edges wil press into the wood, then start the drill and the harde brass wire will keep the burr in place.One question about this to @Maarten and @Jimsky :
Yes, you can do it this way, but... the bur also 'eat' some wood and makes hole appearance a bit bigger which I do like as I called a 'washer' effect.It is possible to do it, I did it with these test pieces. Just press the burr on the of the wire. My bur is 0,8 mm with sharp edges. My wire is 0,4 mm so the burr edges wil press into the wood, then start the drill and the harde brass wire will keep the burr in place.
Yes, Maarten, I am completely in synch with you! They are truly enjoyable moments, and if they are the way you made them, it is double-joy!!! Great job on both: cant frames and stern sections!Before continueing on the stern I removed already a piece of the berth to look at the bow frames, these are the enjoyable moments of a full frame build like this.
Hello John, It is a combination of accuracy of Triden's templates, and for sure, Maartens skils!!! Check my log, post #203 I have not shape mine yet.In that second picture the fairing of the frames look perfect.
Did you sand/fair the frames after you glued them in place or were they sanded separately as per the template stickers before you placed them in the jig?
If this is the result of the accuracy of Trident's kit (and Maarten's skills) then I think a strong recognition and appraisal of the quality of both is in order.
Thx gents for the comments.In that second picture the fairing of the frames look perfect.
Hi Maarten ,what is the purpose of the plastic on the templates?Coming back to the frames, after marking the fairing using the templates I trim the outside curvature fairing of the frames using my sanding disc.
The inside curvature fairing I do with a small sanding drum.
Then the finall trimming with a small file and scraping with a razor blade untill a smooth surface is reached.
Last weekend I ran some preproduction of the stern cant frames.
The first of these are now trimmed and fitted.
Zoly, this is the so-called 'Plastic wrap'. Ask your Admiral, most likely she has it somewhere in the kitchen, It is a very thin 'film' used to wrap the food before storing them in the fridge.Hi Maarten ,what is the purpose of the plastic on the templates?
