I’m thinking of making the doors for the oar ports open. Problem is I’m not sure if they opened to the top or to the side?Hi the gun carriages are a cast brown metal ( I painted them a matt brown), but the rest is pewter on mine as well I believe, as are the carvings. The blocks on the cannons are 2mm ones I had lying around. The rope for the carriages is ca glued on the edges or then to make it look like it passes through a ring. They are eyelet looped on the gunwhales. At this scale, I cold not get blocks smaller. I also made twice as many oars so I could have them out the side like a gallley.
