**VIEW THREAD HERE** |
Going back to the question of a small table saw a few months ago I purchased the Proxon FET for $319.17 + Shipping, and added a finer 80 tooth sawblade. It works well for basic ripping, crosscuts with angle guide and extension, as well as a tilting blade. The numerical adjustments are not that good and I get close before doing a test cut and then use the micro adjustment to refine it. From what I see the Byrns is much better for the control settings but is on the higher price side.Test fit of the Cross Bollards:
Couldn't resist test fitting these little pieces after working on them today.
The deck needs one more coat of paint and then the transom will be installed.
Jan
The choices are also partly made by a recognition of how much use related to the priority to model building and to our own useful life ahead. Some excellent equipment, while serving well, if not an affordable cost to benefit paid out over X years, has led me to pass those by and better use our old age resources where they are or may be needed. As you said, it is a very personal and individual set of choices. Rich (PT-2)Hi Rich,
Your shop/modeling tools sound like great additions and useful pieces to acquire. I’ve been taking notes on what, where and how different tools are bought, used and critiqued by members. There is a lot of diversity ranging from “good enough” to ”high quality precision”. Price seems to be the biggest factor for most. I’m still a “novice” builder and mostly bumble my way through the various stages, learning as I go. I’ve found that my full size shop tools, ie., band saw, 10” table saw, drill press and belt sander are great for 1:1 projects they aren’t much help working with 1:25 and smaller scales.
Jan
Hi Heinrich,You guys make me drool with all your talk about tools!
Possibly the length is related to the thickness of the rail itself. A standard handle portion would accommodate a palm width plus ~3 inchers from the two real brass ones that I have which went through a 1/2" metal railing and are 6" lower part. For models you may want longer ones for placement of faux line loops. Rich (PT-2)Dumb Question:
@1:25 scale how long should the Belaying pins be?? The ones supplied in the kit are about 12mm, but seem short to me.
Jan
That answers that question.Possibly the length is related to the thickness of the rail itself. A standard handle portion would accommodate a palm width plus ~3 inchers from the two real brass ones that I have which went through a 1/2" metal railing and are 6" lower part. For models you may want longer ones for placement of faux line loops. Rich (PT-2)
