Supper???What is for supper?
Left over turkey from Thanksgiving?Supper???
who knows....Left over turkey from Thanksgivin?
Hello Dan, and many thanks for the compliments! We (the members of Alert group builders) are happy to know that our build logs will make it easier for others to assemble this very nice kit. Please check out other build logs, they are well packed with hints and suggestions. Paul, @paulv1958 made his build log as a series of video clips, he even creating an English manual. For sure, it should be somewhat easier for all of you guys! That is the intent of the group build!This built will be my Master build test.... the good part is that I am the last one on the list and I have others to build before
Yes - they had chicken, turkey, geese, ducks but also pigs, sheep and cows on boardDid a ship of that period have live birds on board for meals?
From what I have read the live meat and poultry were for officers after the mast and the crew before the mast had to do with the bad barreled and tinned meat and hard tack not consumed by rats and weavles. Also aboard Victory (Nelson era) were a few wives of the upper officers. Have you run across that? Rich (PT-2)All those animals went on board ships as well as the most important animal required for the new worlds - horses.
You have asked we deliver!! Zoly @zoly99sask is the Man!!!Its great that the moderators have changed the forum to allow comments from all members. Nice progress there mate.
Many thanks, Paul! This is what I thought, but the photo from Wang's model makes me scratch my back of the head. Yes, the cabins will make the assembly challenging but at the same time more interesting. Also, while checking the book's draft I found that the Transverse bulkhead goes under the beamOk, its wrong, slots should go towards the stern( if you place the upper beams in you will see the corresponding upper slots so that they line up either side of the beam( lower & upper slots facing each other))
HOWEVER, adding the cabins changes all of this as the walls go directly over the slots and as such block where the bits would go down. You have to modify the bits slightly to allow. I did say that adding the cabins makes a change! The original design does NOT cater for cabins and as such both must be altered to accommodate.
Hello, my friend, Thanks for the feedback. After zooming (2x) your image I found few notches: one for the Pawl bit (i think), and another for Carling. I am not able to see the opposite side of the beam (facing the bow), but Pawl bit notch all the way thru, but carling is not. Check the image red and green boxesand a very rough mockup of where i think it should be positioned, DL3's notches pointing forwards towards the bow
