Looks awesome Brother.
Hello Joe. Don't even try to wet the timbers, it will make it worse. Watter will raise the grain and made scraping difficult. Scaper must be sharp and scrape direction alone grains, one way ONLY, never back and forth.I saw a post some time back saying to wet the wood first but haven't tried that yet.
appreciate the info Jim I have had good luck using them dry so for me no need to use water. I have a good set of cabinet scrapers I use for making Bows so I was up to date on proper use of scraping tools prior to buying the micro scrapers. I know some folks have had issues with the set, but I was always able to trace the problems they explained to improper use its an angle and pressure game, have to let the tool do the work. mine are still good and sharp and I can feel the burr on them after many uses. how I will ever sharpen them is a mystery lol fortunately they are cheap enough here in the US I can just buy another set.Hello Joe. Don't even try to wet the timbers, it will make it worse. Watter will raise the grain and made scraping difficult. Scaper must be sharp and scrape direction alone grains, one way ONLY, never back and forth.
Cant argue with that. I have several cabinet scrapers that were file shaped for certain profiles. I think alot of folks feel its not in the skill set. If your building these ships especially POF scratch, it's in your skill set you just need to try it. Got nothing to loose.I can fully agree with @pugwash, the best shape scrapers are those you will make yourself. Why? The answer is - you can make any shape you need\want! It is not too difficult, but it is not easy. However, if you scratch-building ship frames, you can make your own shape scarpers. You can use old (dull) hacksaw blades or even 'Exacto' or 'Olfa' dull chisels blades and a rotary tool with cut off disks. Check the image below as an example, courtesy of Sergey @bibigon
thank you very much my dear friendI appreciate your courage to make such a difficult repair. Such an experience makes a master..Ondras
