Nice, I am watching closely.
Rich,You are following a very good path by using dry fit as templates securing the part to be glued in a logical sequence. The sanding blocks are better than my use of fine sand paper rubber cemented to a hardwood backer block. Excellent work as you progress. Rich (PT-2)
Terry,Nice, I am watching closely.
The Robert E. Lee has come too far to stop now! It is such a great build! I’m sure this ship will be just as nice.Terry,
Thanxs for watching. But I am not going fast. A Lee and a Duc needs also attention. I hoop I can compleet The Lee very soon, so I can give the Bluenose full attention.
Dean, you are absolutely right. For now a little bit of Duc, but then The Lee gets again under steam.The Robert E. Lee has come too far to stop now! It is such a great build! I’m sure this ship will be just as nice.![]()
Peter, Look forward to it!Dean, you are absolutely right. For now a little bit of Duc, but then The Lee gets again under steam.
And I am figuring something out for the Bluenose. When the time is there, you’ll see.
I wish for 2021, there will be more hours in a day and more days in a week.
Renards, Peter
![IMG_3878[1].JPG IMG_3878[1].JPG](https://shipsofscale.com/sosforums/data/attachments/187/187262-f5f701d09aa3999a61af61597aa253a2.jpg?hash=9fcB0JqjmZ)
![IMG_3879[1].JPG IMG_3879[1].JPG](https://shipsofscale.com/sosforums/data/attachments/187/187263-916fb2329bf4e9097c7b656ca96a39b9.jpg?hash=kW-yMpv06Q)
Hi Don,Peter all is good, when the frames are faired properly and the bottom of the frame sits at the top of the rabbit there will be no twisting of the plank. The frame you are using may be in the wrong slot but it is not sitting properly in the notch. See the pictures below:
Although the frame(#20) is not totally faired properly I am holding this plank in place with little or not effort, it is not being twisted. Once all the frames are in position and properly faired the plank will rest in the rabbit and against the frames with no problem and there will be no radical twisting.
So as they say "don't worry be happy" and get back to the R. E. Lee!!
I like your idea about adding the "shoe"
Hi Heinrich and all the others,Gentlemen - this is a very tricky one for me to comment on. Remember - I have to adopt an "official" approach here. All I can do from my side is to relate the information to members as given to me by YuanQing.
Part #20 is not beveled. This is underlined by the fact that there is no bevel line on the Part. The cross-section drawing is confusing as it is a combination of Part #20 and Part #21 (the latter which is beveled at the top). YuanQing has already indicated that they will replace that cross-section drawing with a 3D drawing similar to the one that Dean has so kindly posted for us on my build log.
@Peter Voogt Peter, obviously you can go ahead with the rabbet, but I would suggest waiting at least until you have dry-fitted a few properly-faired ribs. As @DonRobinson Don has indicated, that may provide the answer.
![IMG_3880[1].JPG IMG_3880[1].JPG](https://shipsofscale.com/sosforums/data/attachments/187/187285-a8ab3d6a6a9957ecb4760bf1c435573a.jpg?hash=qKs9amqZV-)
Thanxs Don, beautiful macro!Hey Peter, here is a close up:
When the frame is sitting correctly this is how it will look, the edge of the frame is up against the rabbit, so the plank will slide in missing the edge of the rabbit. Bevelling the edge of the rabbit would just move the edge up and under the frame, which is really not accomplishing anything. If there are frames missing or falling short of the rabbit maybe then bevelling it will help, I agree with that.
This is just my thoughts.
Thanks Heinrich,@Peter Voogt Peter - absolutely NO NOISE! This is WONDERFUL!This is exactly why I am so excited having you here as part of the Bluenose Group Build. We HAVE to discuss these things - I cannot say enough how important this kind of discussion is for all members. And believe me - the Instruction Manual is by no means a Holy Script - we have already pointed out that the cross-section drawing which was confusing, we have pointe out the stern decorations which were incorrect and so forth. So , my dear friend, please keep it coming. This is what we need and this is what makes this Group Build so great.
My only concern - as echoed by @DonRobinson Don - if if you bevel where it is not required, you may end up with an imperfect fit. That is why I suggested dry-fitting before you make that decision.
Haha, our reply's where passing each otherPlease NOTE: Part #18 does need to be beveled!
