**VIEW THREAD HERE** |
Hi Heinrich.Hello Jan - Loosen Frame #1 right now if at all possible - before the glue really sets. Just soak the glue lines with water (hoping that you didn't use waterproof PVA ( hence the Bison D2 recommendation - remember)
Hi Jan,
It's time to update your signature - the Duyfken is decidedly In progress!
Is it just me or does this look warped? Optical illusion?Necessity the mother of inventions???
A temporary solution for dry fitting until I can get to the hardware store to get some "stuff" for a permanent setup.
Jan
View attachment 201537View attachment 201538
I think there is a bit more distortion with the photo angle. I’ve been using my iPad to take the pictures and the front to back type pictures aren‘t the best.Is it just me or does this look warped? Optical illusion?
You’re right the parallel lines look curved.I think there is a bit more distortion with the photo angle. I’ve been using my iPad to take the pictures and the front to back type pictures aren‘t the best.
The parallel lines on the deck also look odd. Frame #1 is a bit off, but that’s an easy fix.
Jan
I think you did a great job and I don’t believe the alcohol will prevent future glue form adhering.The "Do Over":
In the post above I've shown Frame #1 is a little askew. This morning I removed it and will reset it later.
But I'd like to share two items.
1) Placing and glueing the deck, I think that would be a lot easier if Frames 1 and 12 were added to the keel after the deck is laid. That way the ends of the deck could be positioned better and then clamped while being glued in.
2) The merits of PVA water soluble glue. I was going to brush hot water on both sides of Frame #1 to loosen it. That process has worked in the past. I noticed this morning that when I cleaned the glue from my metal hobby plate that the Rubbing Alcohol I was using did a great job. So I switched gears temporarily and brushed several heavy coats of Rubbing Alcohol (91% Isopropyl Alcohol) on the joints holding Frame #1 to the keel.
It didn't take very long and the frame came right off. I've no idea of the pros and cons for this method, but for me it provided the resultI was looking for.
Jan
I found that it worked very well, the angle cuts were easily accomplished versus trying to do them with a ruler and a sharp blade.Nice tool! Works great I think.
Ehh - I had to measure them myself too, as this is something which is not complete clear in the instructions
Hi Hans,Ehh - I had to measure them myself too, as this is something which is not complete clear in the instructions
They are a little bit smaller than the ones in the bulwarks, 8 x 8 mm or evt. 9 x 9 mm
