Hi,Jan,
Your moving along nicely, you might finish this ship before I finish the Enterprise.
I like the treenail look, might give that a try on my next build.
I was eyeing how your planks butt into the stern, they look good to me, at least better than mine.
Are you finding this build to be easier than your last one?
I really can’t say if the builds get easier because I’m slowly progressing towards more complicated builds. But on the other hand my confidence in my abilities and skills have vastly approved. I spend a lot of time working my way through SOS build logs and noting the different techniques that members use to achieve the same ends. I’ve stopped fretting over small mistakes, no longer worry about re-doing a botched step and spend a lot more time thinking about a build steps. I currently have two builds going and try to spend some time on each every day, but there are also days that my time is taken up by other activities.
The Alert is a great kit. The hull planking was complicated, I had numerous false starts before I figured out a method. The plans call for severe tapering at both stem and stern. I finally decided to follow the tapering at the stem and let the planks lie naturally following the hull line. It took a lot more stealers at the stern but the final result was better than I expected.
Jan
