Meant to say ability versus cost it would be silly but this way I can still enjoy it.
Thanks Allan
Thanks Allan
Hi Amac, I know exactly how you feel, all the rich kids get the best toys.Like following this build. It is a kit I would love to play with but with my level of ability balanced against the cost of the kit
Hi, Thanks for the compliment. No, I’m not sure at all, I’m not building this as an absolute replica but just for the fun of building something different so I’m not doing any research. The kit instructions tell me grey/green and suggested the contrast on the edges, I had the colour that you see, it looked ok but now that you’ve pointed it out it doesn’t look quite right. I thought that I was going to get the afternoon off but instead I’ve now got my pot of paint out and will paint the lighter green part a light grey instead, that shouldn’t be too difficult and will do me.The harness looks very realistic! Great model!
But are you sure about the colour of the engine mount and the firewall? As far as I know the inside areas where only painted in RLM02 grey (except the visible cockpit in RLM66 black grey, as you show it) without green areas.
Hi, It’s no trouble at all. It’s now much better than it was and it’s good enough for me for now.Didn´t want to bring you into trouble Ken!
Here is a link to a link, how this colour could have looked like:
H070, H070N, H-070N, Gunze, Gunze Sangyo, uniformgrau RLM02 seidenmatt, H070, Mr. Hobby Color, Modellbaufarben, Lacke, Acrylfarben, Wasserlacke, Decal, Decals, Decalerstellung, DS-Design, DS, www.ds-d
H070, H070N, H-070N, Gunze, Gunze Sangyo, uniformgrau RLM02 seidenmatt, H070, Mr. Hobby Color, Modellbaufarben, Lacke, Acrylfarben, Wasserlacke, Decal, Decals, Decalerstellung, DS-Design, DS, www.ds-dwww.ds-design.de
and here another one where it is referenced to RAL, Revell and humbrol colours:
Online Casinos Österreich - 20+ Beste Echtgeld Seiten 2025
Entdecke die besten Online Casinos in Österreich 2025! Über 20 Echtgeld-Seiten im Vergleich – sichere Lizenzen, Top-Boni, schnelle Auszahlungen und große Spielauswahl.rlm.at
As long as your careful the wing stays true, the fit of the parts is exceptional and when the ribs are all in place it is pretty rigid. There will be thin flat sheets to fit over the ribs so when they’re fitted I doubt even with force you won’t be able to twist the wing if you tried, very good for a kitThe wing looks great! Is there a jig or do the parts fit in a perfect angle?
The wrong part is really annoying. I hope AL sends the right part very quickly.
absolutely amazingHello All. Today’s update is the start of the wings. As you can see I’ve been playing with them on and off whilst waiting for paint to dry on my other parts. The initial stage, the spars, leading and trailing edges was simple enough but bending the sheets for nice even curves for the wheel housing parts was a bit tricky. The plan led me nicely through the ribs, flaps etc, everything had to be so accurate as there will be ailerons, air brakes and coolers to squeeze in and the tolerances are tight. The first kit problem has arisen, the wingtips are four pieces, top and bottom for each side, easily identified as they are numbered, they have given me three right pieces and one left, they are large cast pieces and as I said, numbered so a sloppy mistake. I’ve mailed Artesania so we’ll see how good their response is.
I’ve shown the sprue sheet, you will see that even the smallest part has at least six connection tabs. Not only does this lead to a lot of filing to get rid of them but it leaves needle like bits sticking out so that every time that you pick up the sprue sheet you get stabbed, not just once but several times as the parts attached become less and the spikes become more. This is becoming very painful and with the cuts my fingers are raw. At the end of each day there is enough blood on the model for you to believe that it’s gone ten rounds with a Spitfire!
