Truly beautiful work John. Love the recessed bolt detail.
Actually, I did know that about the bowsprit on those ships. It just looks a might odd. I’m sure they had a reason for the forward guns, but if you had any sails or rigging in front, they would be hard to miss. It doesn’t seem all that practical. And I was being a bit of a smart Alec. Forgive me.Paul: Thanks - you are always so encouraging
Vfordyce: Probably "overkill" with those very small recessed pins, but I wanted to explore added details. They will be seen, if one looks lol
Regarding the bowsprit mast, as you certainly know in many of those ships of the period, when the foremast was placed so far forward into the forecastle deck, the bowsprit mast then had no place to anchor within properly - hence the off-centering.
Those guns were chase guns, and most certainly used as don't get to close signals. In any case if fired crews would certainly be sure that their line of fire were unobstructed. PS: guessing here - please members with expertise add some thoughts?
When I decided to properly off-center the mast I did also think about what you mentioned - I think I'm "ok" with positioning.
Thanks for dropping by......
Starting on forward bulkhead framing - will add details along with timbers painted black.
View attachment 237250View attachment 237251View attachment 237252
A MOW in pursuit and coming up the stern of the enemy had the most devastating shot through the transom and through the more forward gun decks and crew members. Glass was not much of a deterrent to the shot. Just my thoughts. RichActually, I did know that about the bowsprit on those ships. It just looks a might odd. I’m sure they had a reason for the forward guns, but if you had any sails or rigging in front, they would be hard to miss. It doesn’t seem all that practical. And I was being a bit of a smart Alec. Forgive me.
I think if I were being pursued by a man of war, I’d turn and give him a broadside down the gullet, hoping to demast him with a 24 or more gun advantage. Then I’d turn tail and run. Or if he’s faster and I’m terribly outgunned, I’d strike the colors because resistance is futile. I will be assimilated.A MOW in pursuit and coming up the stern of the enemy had the most devastating shot through the transom and through the more forward gun decks and crew members. Glass was not much of a deterrent to the shot. Just my thoughts. Rich
