- Oct 9, 2020
did you use a Dremmel to ream the bowsprit hole?
That's about the only thing you can do.I’m hoping this exercise will help keep the boxes from breaking off or coming loose. First, I glue on the back side with Titebond II Premium Wood Glue after marking where they would go on each side. Then I drill holes from the front side inside the marked areas. Finally, I place the tips of wire into super glue and place them in the pre-drilled holes. I’ll cut them off later. View attachment 248042
I just wanted to advise you to expand the hole under the bowsprit.Then sheathe the bulkhead with slats anyway.I also cut the bulkhead at the bottom to get a curved shape.I’m hoping this exercise will help keep the boxes from breaking off or coming loose. First, I glue on the back side with Titebond II Premium Wood Glue after marking where they would go on each side. Then I drill holes from the front side inside the marked areas. Finally, I place the tips of wire into super glue and place them in the pre-drilled holes. I’ll cut them off later. View attachment 248042
Mr. Deep,,,,, where have you been. Missed you so much.......I just wanted to advise you to expand the hole under the bowsprit.Then sheathe the bulkhead with slats anyway.I also cut the bulkhead at the bottom to get a curved shape.
He was treated for 1 week in the hospital.The kidney stone moved.Mr. Deep,,,,, where have you been. Missed you so much.......![]()
Hope you okHe was treated for 1 week in the hospital.The kidney stone moved.
designSo I did cut the hole and trim things. It seems I’m not the only one who did that. Is it a design fault or operator error?
When you go to place the lower wales, I took measurements and followed the 1/1plans. IN my mind, toward the stern, they should be lower. they have them angling up.So I did cut the hole and trim things. It seems I’m not the only one who did that. Is it a design fault or operator error?
Hi Vic. If those supporting boxes are anything like those on the Haarlem, that is one aspect you need not worry about!I’m holding my thumbs and crossing my fingers!
