Le Soleil Royal ZHL Build Log [COMPLETED BUILD]
I’m hoping this exercise will help keep the boxes from breaking off or coming loose. First, I glue on the back side with Titebond II Premium Wood Glue after marking where they would go on each side. Then I drill holes from the front side inside the marked areas. Finally, I place the tips of wire into super glue and place them in the pre-drilled holes. I’ll cut them off later. image.jpg
I’m hoping this exercise will help keep the boxes from breaking off or coming loose. First, I glue on the back side with Titebond II Premium Wood Glue after marking where they would go on each side. Then I drill holes from the front side inside the marked areas. Finally, I place the tips of wire into super glue and place them in the pre-drilled holes. I’ll cut them off later. View attachment 248042
That's about the only thing you can do.
I just wanted to advise you to expand the hole under the bowsprit.Then sheathe the bulkhead with slats anyway.I also cut the bulkhead at the bottom to get a curved shape.
So I did cut the hole and trim things. It seems I’m not the only one who did that. Is it a design fault or operator error?
When you go to place the lower wales, I took measurements and followed the 1/1plans. IN my mind, toward the stern, they should be lower. they have them angling up.
that is just my preference. Unless I measured wrong.
Except when I read how two people lost one and it dropped inside after sealing off the hull. That makes me a little nervous. I think I want to go on the safe side. Thanks for your input, Heinrich. It makes me feel a little better. I had a difficult time with gun carriages coming loose and not being able reach them easily on my Pearl.
