Hello, Jan. Technically speaking, they suggested using a hobby knife as the fairing tool only because it is a common and available tool for most modelers. A much better tool (from my personal experience) is the long sanding stick. The length should cover three or four adjacent bulkheads. It must be absolutely even flat. The nail sanding sticks will not do as they are flexible. You can make one from plywood and double-sided sticky tape. They will last long...but if it is worn out, replace the tape and new sandpaper.he instructions indicate that bulkheads/frames 1 - 5 and the bow filer needed to be trimmed/faired to the engraved laser line Using a SHARP #11 blade. I had to wait until the Admiral was out, since my “carving” skills are nil and I take meds that could be problematic if I were to slip.
Excellent advice, I've been making sanding sticks from scraps using Elmers Glue Stick and sandpaper. I found that once the sandpaper has clogged its easy to peal off and replaced with another glue stick covered piece.Hello, Jan. Technically speaking, they suggested using a hobby knife as the fairing tool only because it is a common and available tool for most modelers. A much better tool (from my personal experience) is the long sanding stick. The length should cover three or four adjacent bulkheads. It must be absolutely even flat. The nail sanding sticks will not do as they are flexible. You can make one from plywood and double-sided sticky tape. They will last long...but if it is worn out, replace the tape and new sandpaper.![]()
Hi Paul,Hi Jan,
And now a word from a total novice...
Tiny sanding sticks are worthless for what you are attempting. I propose a hunk of wood (6-8 inches long - 2 inches wide - 2 inches tall) - you want something you can hold in your hand not only with your fingertips. Use long motions with the sanding block such that you are sanding 3, 4 or 5 bulkheads at a time. Use the char on the edge of the wood to keep track of where you are making changes. The #11 blade idea will never get this done!
If this what you are already doing then just ignore this post!!! Just trying to help!
Hmm, 9 m is about 30 ft, divided by 48 (scale of ship) is about .625 ft, times 12 in is about an 8 in length for a plank. I think I can work with that. The three plank stagger suggested by Alexander should work out, its only thirteen strakes to a side. The only exception I'm making is the first strake, that hull length I'll divide into two 16in pieces just to have a solid reference to the sheer. There is a slight up-curve at both ends of the hull and I want to be able to follow that line as I do the rest of the planking.Hello Jan. I think that Sasha's advice to scale the 6-9 metres lengths to your scale is a good idea with the proviso that the butt joint co-incides with a bulkhead. If the bulkhead is too thin to accommodate the juncture of both planks that make up the butt-joint, glue a widening strip to it - either aft or fore - whichever you deem fit. This may obviously vary from bulkhead to bulkhead.
@Heinrich,The beginning of planking - exciting!You are progressing very well and everything looks like it is under total control. Continue!
Hi Jan,Planking Progress:
I’ve managed to get the Starboard side of the hull completed. So far my method of soaking, bending, fitting and clamping until dry is working out pretty good.
The flip side.
Tonight I’ll be working on the port side.
Jan
Hi Peter,Hi Jan,
That looks like a straight tight long steamboat flatbottom. It's a real challenge to keep her flat and straight.
Thank you for your nice comments. This part is very slowly coming together.Wow Jan! Your planking looks really really good. I love the long lines on this ship and your deft handling of the wood bending over the curves. Awesome!
