Thanks, definitely one very nice kit...Wonderful work, looks very beautiful.
Thank you...Great work from you as always, keep it coming, and one day we will see the completed ship.![]()
what are those candidates? Can you share, if not a secret?I believe maybe month or two and she will be done... already have few candidates for a next build...
No secrets, Mistique or Norske Love...what are those candidates? Can you share, if not a secret?
Thank you.Your sails and your rigging are fantastic and I am speechless.
Dear moreplovacMaking few blocks with a hook... first, wrapped a wire around the block, added a rope on the opposite end off the hook, twist the wire and make a hook. Then, siezing the rope and freeze it with a glue. The whole block was dropped in blackening solution. With seizing the rope and freeze it first, the blackening solution will no "blackened" the rope, because the glue will prevent solution going into the rope. It is not a bid deal if seizing is done after blackening, just rope has to be pulled a bit more so the blackened rope is removed...
Rigging the sprit-sail yard is next. First, the block was rigged and attached to the yard..
... the rope was pulled thru...
Few more other ropes were attached...
Getting crowded up here...
... and ended up on pin. I put a small amount of white glue to freeze the knot... when is dry, less visible than CA glue.
Extra cord length will be cut off later..
Happy modelling...
