     As a way to introduce our brass coins to the community, we will raffle off a free coin during the month of August. Follow link ABOVE for instructions for entering.  |
Thanxs Heinrich.It's always good if one can utilize prior experience in another build. I will follow with big interest.
Sorry to be pedantic - but how do you cut the notches in the beam? Are you using a mill?However, just reversed:
You can see a little more on the photo. Shorten the top bar slightly on the right so the whole still slides a little to starboard.
Looking great! Bring on the ice!Just finished the frame:
..... the yard was visited by the Labor Inspectorate. The passage had to have a full floor first. Otherwise, construction would be halted.
So do that first:
Then I can now continue with the wall covering.
That's ordered. Dean! Did they ask what kind?Looking great! Bring on the ice!![]()
Thanxs Paul.Inspiring work at scale.
Thanxs Paul. This afternoon I realized I still had barrels in stock. So more or less ad-hoc adjustments.I love, love, love this presentation! Simply exquisite Peter.
This is awesome Peter! I really like what you are doing!The IceHold is ready and the ice is immediately delivered:
The storage of the ice can be adjusted to the amount that is left. Shelves can be removed that slide between the guides.
On the side of the FishHold there is a storage on the wall for the shelves that are not used:
The ice consists of large chunks, because they hold the cold longer. If it is used to preserve the fish, it is chopped smaller.
The Bluenose mainly fished for cod. Salt was used for conservation for certain by-catches.
2 barrels of salt are attached to the wall with a rope on hooks.
And the test: sliding the two parts together again succeeded!
The two parts on top of each other. The left 'ear' was slightly bent. That is now back in line.
I can't place the deck beams yet. On the beam that will be placed on the wall, I first have to fit 2 cross beams. They will carry an hatch for the access to the Fishhold and IceHold.
When the 1st and 2nd layer of oil is well absorbed and dry, a 3rd layer is added.
Agreed! Peter has not let innovation intimidate him one bit! But that’s what confidence does for you! No such thing as can’t be done!Amazingly detailed work. If I read all the contemplation that is currently going on with another kit that was designed with the possibility of a split hull, and one takes into account that this was never the case with this kit, then your work takes on another dimension, Peter!
Thanxs Heinrich.Amazingly detailed work. If I read all the contemplation that is currently going on with another kit that was designed with the possibility of a split hull, and one takes into account that this was never the case with this kit, then your work takes on another dimension, Peter!
Hi Dean. We are both in the stage of building walls.This is awesome Peter! I really like what you are doing!![]()
Thanxs for this statement.Agreed! Peter has not let innovation intimidate him one bit! But that’s what confidence does for you! No such thing as can’t be done!![]()
Nice fit, tight joints! That’s the ticket!I am now working on the beam frame with the recess for a hatch. It might be interesting what I use to get a flat right-angle base. I like to show it and who knows it might help someone.
I use this metal 'corner clamp' for that:
Normally you use it to clamp right-angled connections:
2x90 degrees or 2x45 degrees.
I first make the 4 noses of the short beams and the 4 recesses in the long beams to size so that they fit neatly. I do that partly with the router and to stay straight and flat and I finish the corners in particular with the pointed scalpel. So that I get sharp right angles.
Then I clamp it first as a test in the 'corner clamp' to see if everything fits.
Then the four joints in the glue and in the clamp with a starting pressure:
With the following actions:
-I press the 4 corners flat on the metal (white arrows) so that the connections are pressed flat on and into each other;
-I check whether they are perpendicular to the longitudinal recess along the spindle (blue arrows). This can be done by tilting the shadows or the clamp in different directions. If it is off the hook, then some gentle taps against one of the ends to get it square;
- some extra pressure to squeeze the connections together;
-measure the distance between both ends as a last check (yellow arrows).
The result gives, if the preliminary work is done well, 4 nice connections:
Of course you can still check it on the lines of your cutting mat or other angled items (such as Lego blocks).
Then this is a good basis for customizing the other crossbars.
Superb!The IceHold is ready and the ice is immediately delivered:
