Filled the 1st FishHold 'temporarily' until I found 'scale cod' that is to my liking.
Now for €0.02 in ink lost on a print. A little origami (just make a ball and unfold it again) and some crunched ice on top.
The next FishHold ends under the 1st beam of the raised aft deck. On the YQ model, the low foredeck jumps from the last beam (26) to the 1st beam (27) of the raised aft deck.
In the books it can be read that this elevation also functioned as a kind of water breaker to keep the further aft deck drier.
In The Sage, L.B. Jenson clearly drawn that the planking of both decks has an overlap over 2 deck beams:
With the extra 2 supported deck beams underneath.
In the right drawing he has also drawn the end of the deck planks. I accentuated them.
To allow the deck planks to continue under those first 2 'raised' deck beams, I had to make the beams thinner and on both sides the support to have its normal hight:
Installed on the bearing beams and placed a few pass planks underneath:
With the planks a bit past it:
The top and bottom planks are from my own stash that I may be making the deck from.
The middle one is a piece of what YQ supplied. Nice grain in itself too. Maybe I'll cut planks from the 2 sheets.
Made the 2 extra lower beams from residual wood from which the deck beams come:
Fitted between the two bearing beams:
Then you get this double beam layer:
And seen from the bottom:
Everything still dry-fit, because it still has to come out for fitting the FishHolds.
Finally, a photo of the deck beams of the complete foredeck:
