Thank. Also a good way to slow me down.Great attention to detail Charlie.
Found them at Hobby Lobby. An impulse my when I was looking for the hose material. Glad I found them.The new stanchions are definitely a step up. What size of tubing did you use?
figured it needed a little spicing up.Looking great! The white at the ends of the spokes are an interesting touch.
The stanchions look great. After seeing your initial post for the bow I started thinking I could do that as well when I get to the Endurance. The stern ones are giving me second thought. My soldering abilities are below novice skills.First off, Jeff T's comment about the spokes on the wheel convinced me to change them from white to brown. Thanks Jeff T. Looks better now. So the stanchion building got a whole lot tougher. The bow was a snap but the rest of the lifelines are two ropes and the soldering was difficult. I tried several jigs and finally came up with one that worked 75% of the time. Hard to heatsink parts that are only 5mm. They have a tendency to clump up into a ball when heated. I used two pins held everything together while soldering and after sanding with the Dremel they were ready to paint. After installation it was worth the trouble. Much better looking then the ones supplied with the kit.
View attachment 265399View attachment 265400View attachment 265401View attachment 265402View attachment 265403View attachment 265404
Thanks. It will take a while to do but as I've been reminded by others, it isn't a race so I'm keeping it slow and careful this time. Only 48 stations to go.The stanchions look great. After seeing your initial post for the bow I started thinking I could do that as well when I get to the Endurance. The stern ones are giving me second thought. My soldering abilities are below novice skills.
I like the all brown wheel better too.
OO Scale railroad, popular in UK, is 1:76. Maybe look at some of the UK hobby shops for some dogs?Installed the sled dog kennels and the deadeye channels today. You're supposed to install the boat davits next but I'm holding off as long as possible. I have a bad habit of breaking off parts that stand out from the hull with my sleeve while reaching for glue and other things. Wish I could find a couple of 1:70 dogs to add in the kennels.
Thanks - Good idea. I have done some searching in US but not much in Europe. Will renew the hunt.OO Scale railroad, popular in UK, is 1:76. Maybe look at some of the UK hobby shops for some dogs?
HO Scale here in the US is 1:87.
Glenn
