I agree too. The one on the left looks best.
Without a doubt- I think that is a unanimous decisionI agree too. The one on the left looks best.
Just finished the port side and we are looking good!Without a doubt- I think that is a unanimous decision![]()
I think it's hand made on a ropewalk so it has the tendency to unravel. Frustrating at times. It warns you on the spool. Takes a little longer to use but looks better. Not cheep at 5 bucks a spool though.The dead eye rope looks way better. Just curious, does any of your rope try to unwind itself when you make a cut on it?
Charlie and Daniel,I think it's hand made on a ropewalk so it has the tendency to unravel. Frustrating at times. It warns you on the spool. Takes a little longer to use but looks better. Not cheep at 5 bucks a spool though.
...So if you are ever tired from the orthodontist job, you can always open your own bakeryDon't laugh but I have been baking my poly rope and its stops (well, significantly slows down) the unravel. I wrap my rope around an empty soup can and bake it in the oven at 350 degrees for 5-6 minutes.
You're the man Paul. Only laugh when something fails. Next time I make diner I'll try it.Charlie and Daniel,
Now that is interesting Paul, I shall try it as well, I wonder if placing it in a cup with or without water and microwaving it has a similar effect?Charlie and Daniel,
Sounds like a high school science project to me.Now that is interesting Paul, I shall try it as well, I wonder if placing it in a cup with or without water and microwaving it has a similar effect?
Ha! There you go. Wife: what are you doing honey? Husband: melting rope in the oven. Wife: WHAT! Absolutely not, out of my kitchen!!Sounds like a high school science project to me.![]()
No rope soup for me please...Now that is interesting Paul, I shall try it as well, I wonder if placing it in a cup with or without water and microwaving it has a similar effect?
Thanks for verifying Charlie.I spent the afternoon experimenting with a few ideas cutting rope without it unraveling.
1. In boiling wary in the microwave for 5 minutes. - Did not work... Sorry Daniel.
2. Holding it over a candle. Worked well but probably not to safe around something like CA. Scratched that method.
3. Plugged in a cheap soldering iron and touching the rope across the tip. Voila! It will probably burn up the iron having it on for hours but they are cheap. Anyway IT WORKED.
Will give it the acid test tomorrow working on deadeyes and lanyards.
Amen! That's what I did. On thicker rope like .60mm I had to wait a minute or more after CA before I cut, other wise it would still unravel. Now I zap it, CA the end and set it aside instead of sitting there and counting to 60.This is tool sounds like a great idea, however, oftentimes, we need to use the 'cut end' for further processing, like inserting it in the small hole of blocks and\or deadeyes. With the melted end made by this tool, it will be difficult if not possible.
I am using a CA glue: just a drop of glue and an angle cut with a sharp blade.![]()
