Now all construction drawings are searched for eyebolts, round and triangular rings and missing fasteners are drawn in addition.
View attachment 270815The kit contained four triangular rings (above in plastic bag). But as soon as I start, I make all the rings myself. In the case of round rings, the wire is wound on a corresponding drill and cut open with the side cutter. After completion of the eye screws and rings, the openings are bent shut, soft soldered and the components blackened.
Best regards
Thomas
Thomas, what is the brass wire diameter you used ?
Thanks
Daniel
