- Jan 9, 2020
Hello Everyone
Let me show you where I am tonight, some things to take note of and then also one of the options open to the individual builder that I mentioned last night.
The third planks on both sides were laid down today.
Port Side: In addition to fixing the strake to the bulkheads by means of push pins (my primary means of fixation), I also use clamps on the planks themselves which aid in alignment. Until today I had not been able to use them as there was sufficient part of the planks protruding above the deck to give the clamps a proper grip.
Starboard Side: I use Kolderstok's most handy notepad, to jot down which bulkhead/s need/s additional fairing.
Tonight, I am not going to inundate you with a plethora of pictures again as I want to share some brainstorming with you. However, the three pics below show the current status:
Starboard Side
Port Side
Bow: Now here, I have followed Piet's example by already shaping the bowsprit opening in the bow filler BEFORE planking. This means that my next plank cannot extend all the way to the keel. If I do extend it, it would simply mean that I have to cut part of the plank away again.
Thus so far I have laid down three planks: All three these planks were neither beveled nor tapered - they were laid down as they came from their mother.
1. 4mm x 1.5mm
2. 6mm x 1.5mm
3. 4mm x 1.5mm
Now the instructions call for THREE 6mm x 1.5mm planks with their ends tapered to 4mm to be laid next. The instructions are very clear so this is what I SHOULD be starting tomorrow. However, I started thinking and this is where my brainstorming comes in. Please take a look below of the completed build of @pietsan Piet Sanders:
The three colored lines indicate the three real wales ("Berghouten" in Dutch) on the Willem Barentsz. These wales are eventually formed by gluing TWO 4mm x 1.5mm strakes on top of each other to provide double thickness. The Red Line indicates the first 4mm x 1.5mm plank that I laid down, the green line indicates the 4mm x 1.5mm plank that I laid today. The section between them is the 6mm x 1.5mm plank that I put down yesterday. The Yellow Line is for future reference as we are not yet close to that.
Normally speaking, the wales are only attached to the hull after the planking has been completed and sanded smooth. Then, it is of course a real challenge to fit those wales. And this is what got me thinking.
Here I have my two future wales sitting beautifully accessible - both by push pins and clamps. True, the bottom one is tricky because the clamps will have to go in from underneath, but why do I not add the double planks on top of the first ones right now and finish off the first two wales. Just think, without push pins and without clamps that second plank is going to be a "real-you-know-what" to align properly and fix.
Please tell me what you guys think - I look forward to your comments and suggestions.
Starboard Side
Port Side
1. 4mm x 1.5mm
2. 6mm x 1.5mm
3. 4mm x 1.5mm
