While at dockside in our port my wife and I realized that we had a very short window to complete our annual baking and micro decorations of stores before our son drives out to Teton Village where he is a ski guide for a few months before heading up to Alaska as a helicopter ski guide. The modeling tweezers come in handy. No hazard other than caloric as the stores are edible unlike the usual items handled for the Kyrenia: Two loads for inspection:As I planned I have moved aft to the quarter rudders and tricking the kit up to better match the Kyrenia II reconstruction which was sailed on several experimental voyages.
First is a photo that Mensis took of this area for my rudder rigging:
Next is another view aboard of the aft deck area for the helmsman:
Seeing some added supporting members on top of the rails to secure the rudder pole I added those as well as some additional belaying pins aft which were likely used to secure various lines as needed at different times. I am not sure what lines we can see hanks hanging there so I will leave those out.
Here is my own birds eye view of my deck in preparation for the rudders.
For a test I places one of the rudders with a wrap to be secured to the projecting short
added member.
Not shown here I then ran the yard brace to the stantion and pin aft of the rudder for a line check. It passes outboard of the helmsman so all is OK so far. Also not shown is where I spliced the fixed end of the doubled sail sheet which is forward of this and closer to the aft leading brails pin rail. A touch of clear was applied to fold the sheet tightly through the block as there will be no tension on this sail to obtain the same bend as if it were taught. If all looks OK I will next complete mounting and securing the two rudders before completing the sheets and braces. Rich
Securing additional handlers a second loading was presented for inspection:
Approved or not they will be carefully loaded and padded in a tin without any tarrif to be paid.
Rich and Ann (PT-2) For the Admiral/Baker
and cable set on foredeck:
