Hi Ron. It is now the third time I have had thread confusion- use my phone too muchGrant
I would like to say that is my planking job however, that’s from a posting Heinrich made from Han’s G build. If mine turns out half as good as that one I’ll be ecstatic. I’ll be starting the planking soon and to this point I really like the quality of the kit
Ron
. im sure you will be ecstatic with your outcome and yes those are super high standards to chase. Good luck and enjoy.Grant, I feel your pain. When I go between, iPad, iPhone and desktop I often get threads mixed.Hi Ron. It is now the third time I have had thread confusion- use my phone too much. im sure you will be ecstatic with your outcome and yes those are super high standards to chase. Good luck and enjoy.
Thanks H.
However, you are in China and I am in Florida and I didn't take a macro shot![]()
Your planking looks REALLY good Ron - you have absolutely nothing to be worried about. It is always an exciting next step to remove the shell from the framework, but I am positive that it will go well. The 3M Fineline tape is a very good idea.
Ron you will not crack anything and as to "walnut" that wood is tough and resilient - as you experienced during the bending. For the WB build though, I would recommend that you get the Kolderstok plank bender. You don't need to get the soldering iron part of that as the EU power ratings are different to that in the USA, but you should get the different heads (fitments). @Pathfinder65 Jan will be able to tell you exactly what power (voltage and wattage) soldering iron he uses.
Great stuff - then you are all sorted!I already have them Heinrich. That’s what I used for the bending. As you know some of them required a 90 degree twist.
I use a 30 watt iron. Works great
Wow that is small. Very nice planking work.I feel like I'm constructing a dory
Hi Ron.Well done with your planking. That is small...View attachment 276584
Whew, removed from frame without hearing the crack of wood.
OBTW, did I mention the size (Or lack of) of this model. 28 cm completed. I feel like I'm constructing a dory.
Now to the internals to stiffen in up.
. awesome job.Yup, been there, done thatI always knew I couldn’t walk and chew gum at the same time. Along with my Speeljacht I’m (kinda) working on parts to another (unnamed) model and couldn’t find enough 1x4 strips. Duh, I was looking at the wrong kit.
