You were originally going to tie the knot. Did you mean get married (English idiomatic expression) or tie clove hitches?This weekend I didn't feel like tying the knot. So I made a crosscut sled for my Proxxon FET
View attachment 276634View attachment 276635View attachment 276636View attachment 276637
my old one was not strong enough and not square either.
I'm already married a long long long time ago. Hatcher I meanYou were originally going to tie the knot. Did you mean get married (English idiomatic expression) or tie clove hitches?
Ordered from Amazon and shipped from Micro Mark. Have seen these advertised and had to try one![]()
Ran a few test cuts on various materials and this thing does cut. You have to be careful and keep the blade moving or it will burn, as you can tell if you look closely at the tip of the blade which shows some discoloring.
I was looking for a way to cleanly cut openings for cannons. I believe this is just the ticket.
Be interested to hear what others have experienced with this tool.
It does have a 50/50 duty cycle to avoid overheating and it will shut down if you exceed a 10-minute continuous run time.
Well, I have been thinking on this tool for a long time, to use it as you mentioned or similar situations, like opening a window. Will you be so kind to post pictures or let us know how it worked for you.
Thank you !!!
Daniel
Мозе ли нека информација висе о васој масини ?Који мотор сте ористили и тако даље. Хвала
Yes Daniel these desks are a great back saver and make it a lot easier to work on models.
I have purchased 2 of similar desks from Home Depot but it comes with 2" thick wood top and it's 24" x 54"
and it will handle up to 300 lbs.
For you folks, if you live near a H.D. it's now on sale. https://www.homedepot.com/p/Husky-52-in-Adjustable-Height-Work-Table-HOLT52XDB12/301809830
While installing the ribs on my Speeljacht I had two ribs that were too high and had to cut the tops off below the top of the hull to allow space for inserting the deck framework. This being a very fragile structure I didn't want to put any excess pressure on the hull with a hobby knife or razor blade. There was no room for a Zona saw either so out came the Wonder Cutter and with barely any pressure it cut through the walnut ribs like a hot knife through butter. This is the first time I've used it other than some test cuts. It won't be the last.Well worth the bucks IMHO
I have a pile of those also. They are good for most jobs, but after a while I needed ones that could reach deeper, so bought a a dozen of these longer ones at the link below. The tips are rubber and grip better than the swiveling plastic tipped clamps, and they are still inexpensive. Currently Amazon is out of stock, but there may be other sources. Good tools are where you find them.Spring Clamps.
I needed to replace and add more clamps for my little workshop. I found a vendor on line whose prices seemed reasonable.
PJ Tools
I ordered both the 4 1/2 and 6 1/2 inch clamps. They seem to be quite substantial. The order arrived within several days after being placed.
Their service was excellent.
Jan
