The next step for me is to form and glue in the numerous internal trusses to stiffen the hull. The above image is taken from Hans Groenberg excellent build log of the Speeljackt from which, I'm gleaning information for my build. Thank you, Hans
Here you can see Hans using the bender I referred to in my previous post #34.
That is one of the three tips and is very useful in forming the trusses around one of the removed formers.
Here I used one of the formers to bend around. I soaked the wood then used the bender to form the wood around. I will cut it in two when dry and that will give me both side of the truss. Only XXXXX trusses to go.
