Great minds think alike. Actually this came with my kitOkiedokie! That is the same as on the WB.![]()
Thank you GrantOutstanding Ron.
Nice balance of wood tones to set off the brass hinges. RichView attachment 282871
I wanted to tone down the contrast between the Walnut and the Abachi, so I gave the Abachi a coat of medium oak stain. The hatch is coated with Danish Oil, and I know the remaining walnut will have a similar hue when coated.
I like what I see so I'll also stain the foredeck with the medium oak.
Ron
On the lower one there was no place to add clamps, so I tacked it with CA. BIG mistake as I'm not sure I can remove it without breaking.
Hi Ron. Hope you are well. Eish(as we say here in SA)....I think Heinrich is going to lecture you re using CA glue- he “rasped” me alreadyApplying the Wales turned out to be far more difficult than I anticipated. Reading in Hans log of his build he stated, "I find this one of the most difficult jobs with every ship I build." When I read that I questioned it. Not anymore. I buggered the lower Wales and have yet to correct them. The picture shows the upper wale with glue drying. When I remove the clamps, I'll see how this one looks. Fingers crossed.On the lower one there was no place to add clamps, so I tacked it with CA. BIG mistake as I'm not sure I can remove it without breaking.
. I know you will find a way to sort this out. CheersHi Ron. Hope you are well. Eish(as we say here in SA)....I think Heinrich is going to lecture you re using CA glue- he “rasped” me already. I know you will find a way to sort this out. Cheers
No guessing Ron- promiseGrant,
I haven't been scolded like that since my industrial design teacher threw his chalkboard eraser at me for a comment, he apparently didn't like
For the past 50+ years I've been building RC aircraft and CA was always a part of building. It's not that using CA (Sorry Heinrich for swearing) got me in trouble it is because I used thin rather than thick to tack some of my pieces down as clamping wasn't possible. Of course, the thin wicked to places I did not want it to.
PS, you can tell my age by the reference to chalk board and eraser.![]()
. Yep CA glue... I see a lot of guys use it and I think getting the right make and viscosity is also a learning curve. Being a rookie I do try avoid it as it does seem to end up where I don’t want it...has a mind of it own in my hands.You can always tell the guy’s who use CA they sit around chewing glue from their fingertips. Not to mention the bits of flesh adhered to their model. You would be amazed at how far thin CA will wick along the grain of the wood especially balsaNo guessing Ron- promise. Yep CA glue... I see a lot of guys use it and I think getting the right make and viscosity is also a learning curve. Being a rookie I do try avoid it as it does seem to end up where I don’t want it...has a mind of it own in my hands.
Hello, Ron. Yes, using CA glues require some knowledge and experience, but I don't recall chewing any glue, especially CA when I learned how to use it! It is real poison if it comes to the mouth. Avoid at any cost chewing it!!!! Unexperienced use of CA may lead to accidental spills and sticking to your skin, it does happen. It could also destroy your plastic model if you touch it with fingers 'in glue'. Not to mention that some CA fumes, can hurt your health, but... (read my answer to Grant below)You can always tell the guy’s who use CA they sit around chewing glue from their fingertips. Not to mention the bits of flesh adhered to their model. You would be amazed at how far thin CA will wick along the grain of the wood especially balsa
Being a rookie, you may want to know, that there are specific cases where using CA is highly desirable, and might be the only solution. For example, when you glue the planks around the bow\Stern area, were using the standard set of clamps is not suitable, here comes a CA gel. You would get drops of CA along the plank, where the rest of the glue is wood glue. In such cases, CA perfectly works as the clamp. You still have some time to adjust the plank in the correct position, though. Don't be afraid to use CA glue. Have you ever seen the movie series by Olga @shipphotographer.com? She uses CA in many occasions.No guessing Ron- promise. Yep CA glue... I see a lot of guys use it and I think getting the right make and viscosity is also a learning curve. Being a rookie I do try avoid it as it does seem to end up where I don’t want it...has a mind of it own in my hands.
Hi Jim and Ron- quick hi-Jack of your log Ron. Thanks both of you re the CA chat. I did not know it came in a gel so much to learn which to use and when. Jim I have seen some of her you tube threads however I will have a look at more. I used it to seal some of my rigging but became to risky as it hardened some of the loops ( not only knot) and didn’t look good. My application thereof I know....Ron thanks for opening this discussion as I did learn something here. CheersHello, Ron. Yes, using CA glues require some knowledge and experience, but I don't recall chewing any glue, especially CA when I learned how to use it! It is real poison if it comes to the mouth. Avoid at any cost chewing it!!!! Unexperienced use of CA may lead to accidental spills and sticking to your skin, it does happen. It could also destroy your plastic model if you touch it with fingers 'in glue'. Not to mention that some CA fumes, can hurt your health, but... (read my answer to Grant below)
Grant,Hi Jim and Ron- quick hi-Jack of your log Ron. Thanks both of you re the CA chat. I did not know it came in a gel so much to learn which to use and when. Jim I have seen some of her you tube threads however I will have a look at more. I used it to seal some of my rigging but became to risky as it hardened some of the loops ( not only knot) and didn’t look good. My application thereof I know....Ron thanks for opening this discussion as I did learn something here. Cheers
Thanks Doc. I’m just anxious to work with something a little largerCap rails look first class Ron! Congratulations!
