**VIEW THREAD HERE** |
Hi John,View attachment 283527
the handles needed to be filed a little bit for a nice tight fit as in the top handle,
then they were tapped in place with a small light hammer, I then pulled them back out and applied a touch of CA glue and replaced them back in place,
all the handles in place,
and approx where they will sit on the fore deck,
approx where the funnel will sit, it has of course to be trimmed to size yet,
thanks again for all the comments and the likes,
best regards John,
Hi John,View attachment 283875
Just another warning about these plans, they look great but make sure you check everything, this is the top of the engine room, the vernier is measuring from the centre of the funnel to the outside of the casing, 60mm, the next line out from the vernier is the hand rail that runs along side the engine room casing,
but when I measure the other side it is 60mm to the hand rail,
Here is a closer clearer look,
and the other side, so just be careful,
another thing that I noticed was the port hole for the galley, they show the top of the port 15mm below the galley roof line,
but 15mm down from the roof there is still a curve in the side wall, so I will have to lower the port to fit, there have been another few instances of these discrepancies,
Great idea with the quad John, lovely work.View attachment 283870
Next up is preparing for the superstructure, both the sides of the engine room and also the galley are rounded at the top, so I bought some wood quad of the right size for the Galley which was 22.5mm quad, the shortest length I could buy was 2.4m so I cut the amount needed for the top of the galley and then cut some of what was left down to the right size for the top of the engine room,
sitting over the plan, just the right size,
so I had to cut this quad down to 12mm to fit for the engine room top,
this is the base for the engine room structure, pretty straight forward construction,
and another view,
best regards John.
Love your woodworking, and many thanks for sharing the step-by-step tutorial.
Very ingenious way of making and fitting the handles, John. They look great!
Cheers,
Stephen.
Thank you Brian for dropping in and viewing my LT100 and your supportive comments,Hello John, just catching up on your build log, and its coming along nicely.
Thanks John,And also a big thank you to you Steve for all the support idea's and lovely photos of your LT100, you have helped me enormously, LT100 is a beautiful ship to build but there have and will be frustrations along the way, but that is all part of the journey and the fun of the build.
I hope you are feeling rested and relaxed I look forward to seeing you back at your LT100 soon,
Best regards John,
