Concurrent with the introduction yesterday to the construction of the Willem Barentsz replica, work in the Nantong Shipyard continues.
Following the conclusion of the grating and deck hatch, I started with the planking of the upper deck. Seeing that a good deal of this deck will be visible, it requires a great deal of care and good planning. For that I chose to emulate
@pietsan Piet Sanders’s planking pattern as indicated below. I am only showing this section of the deck planking for the time being.
Photograph:
The word “pattern” is a term that has to be loosely applied, as Piet decided to plank his deck according to a “wild” pattern – so typical of Dutch ships. This means that there is no fixed or prescribed pattern that will be adhered to, but that the planks will simply be placed at random. This is how the Dutch shipwrights did that using the planks that they had at their disposal at any given time.
By his own admission this is the first time in his 40-year modelbuilding career that Piet has done this. I decided that I wanted to emulate his pattern which of course meant that I had to plan very carefully to copy his look. Using the above picture, I carefully marked out his layout and got going. As usual for a Kolderstok model, 4mm Abachi wood is used for the deck planking.
The picture above shows the current state of the deck planking with the red lines indicating the section completed. Obviously, no scraping, sanding, caulking or treenailing have been added at this stage. On the subject of treenailing - that is not something that you are likely to find in Piet’s builds, nor in mine.
With the planking thus far, the next logical step would be to remove bulkheads 1-6 (the bulkheads from the bow to midships)  to facilitate planking the bow area and the rest of the deck. BUT … before that could be done, it was now time for a step I was really not looking forward to – that of gluing the cap railing to the model. Bear in mind that this is a 2mm x 3mm walnut strake that has to be glued HORIZONTALLY on top of the existing planking. As these planks have to be edged-glued only, there is only a 1.5mm gluing area to work with and to get this plank to lie squarely on top of the edge of an upright plank was no easy feat. The other challenge was finding a satisfactory way to clamp and weigh down this plank sufficiently while the glue was drying. The port side caprail required two attempts before I was satisfied, while the starboard side went on beautifully and presented no problem.
This top view shows the two caprails installed and the state of the deck planking thus far.
The next three steps on the agenda are:.
Remove bulkheads 1-6.
Complete the deck planking.
Build up the bulwarks at the stern.
Hopefully, I will soon be able to show you some real visible progress. Until next time - thank you so much for visiting, commenting, liking, participating or advising. It is greatly appreciated.
