As I wrote in my reply to Peter; I thought the forward and aft frame surfaces to be free of any interface, other than a contact surface for the cross beams. So, based on your and Peter's reaction, I'm holding back on applying any finish at this stage.Oil and glue is not a good idea - Peter is absolutely correct. I know it is tempting, but rather prevent frustration later.
Thanks!Hello Johan, seems to be you're faster then me ... My compliments for the work already done!
Hi Johan. Building on different stages of the frames keeps your mind clear. And a nice treenailing on your frames.Ongoing fun on the trenails of the frames. 12 Frames complete so far.
The "shipyard" with frames in various stages of completion.
Hey Peter,Hi Johan. Building on different stages of the frames keeps your mind clear. And a nice treenailing on your frames.
“Wie wat bewaard, die heeft wat!”. Who kept something, have something.Not so much in terms of progress, but a few weeks back I experienced some frame breaks, which I repaired, using pins and adhesive. On frame sixteen, the frame broke at deck level with about a 60* angle relative to the deck plane. I repaired this frame with my favored method. Yesterday evening, while I was inserting trenails in the frame, the repair became undone, meaning I used the wrong repair method for that particular break. The frame breakage may be for 70% contributed to my clumsiness, the remaining 30% I blame on the brittle pear wood. I tested that on the remains of the broken frame part and I found that the wood breaks with little elastic deformation and almost no warning prior to failure.
In all it took a couple of hours to perform the repair. A good thing I didn't throw out the leftover waste material...
Broken frame (right) with replacement part drawn on a leftover piece of wood on the left
Removed broken frame part from frame assembly. Piece of cake; some steam and it became undone very nicely.
Raw cut replacement part.
Completed frame assembly with raw trimmed frame part.
Semi-final trim and repaired frame 16 assembly. Glad it's done...
(Final trim prior to take place prior to planking.)
One moment of carelessness is all I need...“Wie wat bewaard, die heeft wat!”. Who kept something, have something.
A nice replacement. But hopefully it is ones.
And I won't part with what I have very easily.There is actually quite a lot of wood left on those frame cut-out blocks.
Thanks Dean, I probably could have used a different geometry for the top bit, but I wanted to be able to check the repaired frame against the drawing, to ensure proper positioning later in the jig.Keep in mind, all of the frame above the thin area will be removed later! That is the top of the bulwarks.
See below, I marked the approximate cut off line...
Yeah, the frames are delicate, especially where the cross section of the frames changes abruptly.Johan, I have broken at least three frames ... but with a little patience they are back "skilled and enlisted"!
Also because the frames, in that point, do not have a great job to support, are glued to the bulwarks and to the beams of the bridge.
By the way, a great job of patience and manual skill!
Hey Frank,View attachment 286115
Buona sera Pietro, può esserti utile?
