- Oct 9, 2020
Well here we go, my first build log. This is going to be a multiyear project as I am very slow at these things.
I will not put together an unboxing video as there is already one on Youtube:
I was thinking I would show a couple of pictures to start with. The first pic shows a sample of the manual part 1. There are 2 manuals for this build. Behind the manual are a set of plans that show all the part numbers. If you are familiar with Amati's Titanic build then you will recognize the process for building the Bismarck. First, you identify the part that you need for the assembly. You have to label all the laser cut parts on their respective sheets using the plans. Next, you cut the parts out that you need, based on the manuals, and then you must deburr all the parts.
For this part of the build it is all wood, so I just use basic carpenter's glue to assemble the frame. Picture 2 shows the length of the beast. It is about 50 inches long.
