Hello,
It is a master's job.
Hi Marc,We’re literally coming down the home-stretch with Dad. We moved his furniture and belongings, this past weekend, and we will move him this coming weekend - HUZZAH!
Naturally, work on the ship is fairly meager, but I did get the deck sheathing and stove painted, and I did manage to make-up and fit the forecastle beam that will be visible at the break of the forecastle deck. A montage that shows my paint processes, particularly for my natural “oak” finish:
For some reason, I can’t load the other two pics of the sheathing because of an “unknown server error”. Anyway, the process is pretty straightforward; flat black spray primer, followed by Citadel silver (allowing some black to peak through), finished with grey enamel wash. The enamel wash picks up all the nail heads and sheet seams nicely, while giving an oxidized metal finish. The white stripes are masks for where the stove glues down.
The stove begins with Modelmaster Random Tan as my base coat over white enamel primer:
Although it will never be seen, I chose to represent the brick work that is sandwiched between iron and wood.
Next, I slather the whole thing in Windsor and Newton medium grey oil, and allow it to sit for five minutes, or so, before wiping most of it away. This paint gives the wood a pleasing silver-ish cast, like newly oxidizing oak, and it gets into all the plank seams and grain structure:
Next, after allowing it to cure for a few days, I do the same thing again with W&N Van Dyke Brown. This is what restores a sense of woody warmth to the surface, while enhancing texture and depth:
The plate mounted to the deck:
The iron blacked-in:
I decided to rub some powdered graphite over the black, so that the lattice would pop a little. Again, this will never be seen, but I wanted to play around with powder effects. It is subtle, but effective:
Lastly, the stove on-board:
The stove gives me a central glue connection for that beam, which will lend some rigidity to the whole deck structure.
In other news, I have 2 of 3, aft bulwark gussets fitted and installed. All the prep work on the last bulwark is done, so I will resume painting soon.
I hope all are well, as the holiday approaches. Thank you all for stopping by. More to follow!
.Hi Marc,I’ve done a fair amount of hemming and hawing over a number of things, but I eventually arrived at the place(s) I think I need to be.
For clarification of the earlier discussion; this is the essential problem of my stern winding out of square. Note, how the starboard aft edge of the upper bulwark increasingly extends beyond port:
I thought I might try drawing arcs of round-up that ranged from extreme to conservative:
I started with the extreme line (far right), but ultimately - a more slight increase of round-up (middle line), appeared to me to be the most organic possibility.
Here is what my ultimate choice of round-up looks like from the starboard side:
It is just enough, I think, to help balance this incongruity - if not completely.
It seems to me that I can also help balance this out when I make the upper stern balcony. Here, I have pulled a uniform cardboard template just away from the port side, so that the outboard edges of the stern balconies align:
I think this will help align visual perception at the exact point where it is most important.
At the end of the day, I am pleased with the slightly increased camber of this bridge-piece:
One thing that has become interesting to consider is this: in gluing up the aft bulwarks, I was very conscious of establishing a realistic sense of tumblehome, as the bulwarks rise. Even accounting for my initial increase in breadth, in the early drawing, I inadvertently maintained the slab-sided verticality of the kit stern. In the left margin, I have noted the discrepancy between where I have arrived, dimensionally, versus where I began schematically:
Pictorially, here is the discrepancy for real:
What is completely fascinating is that the upper width of the stern is almost identical to the stock dimension. Here is the stock poop deck, in place:
Even though this is not where I thought this project was going, when I started, the improved sense of tumblehome was well-worth the sacrifice in stern-width. This isn’t perfect, but it looks more right than wrong:
A montage of development for the next tier of stern lights:
The pilasters of the lower balcony rail don’t seem to align, but this is not reflective of reality. Again, it isn’t perfect, but it’s pretty close.
After drafting:
This isn’t perfect. The drawing can be improved upon with the carving tools, themselves. For the most part, I think this works. I wonder whether I should follow the Berain drawing a little more closely and include an extra line of horizontal window mullions. The false side lights, at this level, have five horizontal lines, but I am trying to balance this tier with the actual stern lights below.
Just for fun, a different iphone filter - Le Soleil Noir:
As always - thank you for looking in. Bon noir!
